Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 06-15-2004, 01:39 PM   #1
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
Default Lm-1
Had any one used the Lm-1 unit to tune the car?
How does it works? do you like it?
Elliot
Elliot is offline   Reply With Quote
Old 06-15-2004, 07:41 PM   #2
25rstautoxr
Member#: 43958
99 RS Asphalt-01RS
Dirt-01 Forester swapped
I bought one and have to say I like it. I did have problems with analog outs interfacing with my Link plus computer. Overall easy to read and use.
25rstautoxr is offline   Reply With Quote
Old 06-16-2004, 08:18 AM   #3
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
What is you target lamba when you are reading it from the link logs?
Do you have rpm pick up?
Elliot
Old 06-16-2004, 04:01 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I like mine...I think the RPM pick up is available but costs extra...
Old 06-16-2004, 11:41 PM   #5
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
Ive used it, and it works well, you have to pay an extra 150 for rpm pickup, but not necessary..
Pi7467mp is offline   Reply With Quote
Old 06-17-2004, 10:39 AM   #6
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
Any place to buy one used or to lease one for two weeks
Elliot
Old 06-17-2004, 11:22 AM   #7
25rstautoxr
Member#: 43958
99 RS Asphalt-01RS
Never got it to work correctly with the link logs. I did get it to work with the o2 autometer gauge. When tuning I just had another guy watch the lm-1 and do pulls in third gear.
Old 06-17-2004, 02:45 PM   #8
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
That 's want I want
Old 06-17-2004, 02:57 PM   #9
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
you hooked it up to an autometer a/f guage? How did you do that?
Old 06-17-2004, 03:32 PM   #10
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
I also had problems hooking it up to my TEC-II...
crash is offline   Reply With Quote
Old 06-17-2004, 04:31 PM   #11
25rstautoxr
Member#: 43958
99 RS Asphalt-01RS
I bought the analog output cable, you can program the lm-1 via a laptop and serial cable. I cant remember the exact figures I put in for the autometer gauge. The autometer gauge doesnt work like it did with the factory o2. The autometer works from zero to one volt, I made the lm-1 read at .5 volts=to 14.7 air/fuel. In simpler terms: when the autometer gauge reads in the dead center I'm perfect air/fuel ratio. When less we are lean, and more is richer. Simple, but not exact, the gauge is more of an idea of where you are at.
I dont have the ratio for the link and the lm-1 to work. I could probably find out, but I am lazy. My car still is acting up and my runs are not consistant to worry about. Hybrid coming soon.
chris
Old 06-20-2004, 02:50 AM   #12
eightballrj
Member#: 18520
2005 L GT Limited
If I may since I was trolling around the NA-T forum I would have to say that I LOVE my zeitronix ZT-2 that I got a week or so ago!! Check them out at zeitronix.com
eightballrj is offline   Reply With Quote
Old 06-20-2004, 11:59 PM   #13
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
did you try one of those 50 dollar output converters? you can just plug the wideband into it and then plug the air/fuel gauge into the converter and it converts the signal. Maybe that would work better.
subiekid is offline   Reply With Quote
Old 06-21-2004, 03:10 AM   #14
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
I got mine to work with the TEC II. Actually, the makers of the LM-1 recommend you use the 5-volt output since it has more resolution than the 0-1V output. You just have to make a 5-1 voltage divider circuit.
I programmed my LM-1 to output 0V @ 16:1 and 5V @ 10:1 and the TECII to handle these same values.
I have the LM1 hooked up to the voltage divider to divide the 0-5V signal to 0-1V and hooked that up to the TEC II and the autometer AFR gauge. With how I programmed the LM-1, the leanest light is @ 16:1, halfway is 13:1, richest light is 10:1. You can figure out what's in between from that.
Vic
cRayZee is online now   Reply With Quote
Old 06-21-2004, 07:48 AM   #15
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
How you made the voltage divider?
Elliot
Old 06-21-2004, 10:26 AM   #16
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
Vic
Vic, how does your dataloged EGO for the tec-2 look like, with the LM-1? I've got the exact same setup as yours, everything works except the EGO data looks a little noisy, jaggered, not smooth like the narrow band EGO used to be. At first I thought it was noise from the ignition but I found it was still there with the engine off. Just wondering if you have the same issue.
Boostup! is offline   Reply With Quote
Old 06-21-2004, 12:48 PM   #17
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
Elliot
Search for my name in the Engine mgmt. forum. I posted a simple voltage divider circuit schematic.
Boostup, how noisy is your signal? Mine isn't exactly smooth either, but I think it's giving me a much better indication than the old narrowband.
Old 06-21-2004, 01:35 PM   #18
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
Vic, mine has an AC component of about 3 Hz on top of the DC signal and yes, I agree, it's still reading good and is definitely more accurate than the narrowband sensor. I just don't like how the datalog looks when comparing Actual AFR to Intended AFR.
I think it has something to do with the output update rate of the LM-1....which is probably too fast compared to the other sensors that is being dataloged by the Tec-2. I may have to build a 3 HZ lowpass circuit to filter out the noise. Can you tell me what's the frequency content of your noisy signal?
Old 06-21-2004, 01:56 PM   #19
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
I have no clue I haven't done a datalog in a while. My laptop's battery's gone to the crapper a while ago and I haven't replaced it.
Old 06-22-2004, 03:32 PM   #20
crash
Member#: 1440
05 LGT Wgn; 04 FXT
Vic
Did that using the filter and divider described here:
http://www.innovatemotorsports.com/f...?s=&postid=813
The voltage at the TEC was > 1v so I knew it was reading wrong.
Will that circuit do the same thing yours did?
How did you wire up your TEC (there's a +EGO and a -EGO wire and I only saw one in the schematic you posted:
Old 06-22-2004, 03:53 PM   #21
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
It's been a while. I think I only hooked it up to the EGO +. You can check when you're idling and reading the tec monitor and LM-1 and see if they're reading relatively close to each other (The tec monitor will be moving around a bit/kinda noisy)
About that other circuit -- it's using output1 for the autometer afr gauge and output2 for the ECU. The first part is just like my voltage divider, using 12kohm for R1, and 3kohm for R2. The rest is the filter. The line I set up as ground in my schematic, I guess is supposed to go to the EGO - input.
Also, the tec internally multplies the EGO voltage by 5. That's probably why you see >1Volts. You should see what AFR the tec maps the 0-5V in the oxygen sensor calibration screen in wintec.
I'd like to try that filter circuit.
Old 06-22-2004, 05:40 PM   #22
Elliot
Member#: 12732
2000 2.5RS-T
Titanium silver
to which cable you connect this output. rear o2 sensor( used by the link) have four cables wich one is the signal cable?
Elliot
LM-25 no more =[ ...how are the LM-60s WRrexu Tire & Wheel 11 10-26-2009 10:19 PM
Nokian NRW vs. Bridgestone LM-22: a day of "testing" Jon Bogert Brakes, Steering & Suspension 4 01-03-2001 01:27 PM
What's the difference between the BS MZ series and the LM series? V6 Brakes, Steering & Suspension 5 12-21-2000 07:12 AM
Blizzak LM-22 first impressions Jon Bogert Brakes, Steering & Suspension 16 11-30-2000 01:56 PM
