Old 06-15-2004, 03:43 PM   #1
chahny
Member#: 42750
1995 Legacy Outback
Now 25% more Blue!
Default quick radiator fan question
When you turn the A/C on, should both fans turn on? Only my driver's side fan cycles on and off and I'm worried about proper engine cooling as it gets hotter outside.
Thanks
oh yeah, I searched using the terms 'fan or fans and a/c' and found too many useless results
chahny is offline   Reply With Quote
Old 06-15-2004, 04:23 PM   #2
GotTurbo
Member#: 64186
1998 A MONSTER
SOON BMW STEEL GREY
well if ur drivin i dont think it matters that u have either fans on. the coolin from the car drivin will not be a problem. ill look at my car tonight and get bak to u
GotTurbo is offline   Reply With Quote
Old 06-15-2004, 04:24 PM   #3
Bakergtt
Member#: 59207
'05 X was 98 LGTT
I thought the two fans were for the radiator not the A/C?
Bakergtt is offline   Reply With Quote
Old 06-15-2004, 04:29 PM   #4
GotTurbo
Member#: 64186
1998 A MONSTER
SOON BMW STEEL GREY
actually i think that ur right, those fans might not be for the a/c, i have a book on the car in my car. ill look at it tonight and get bak to u
Old 06-15-2004, 05:44 PM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
You are correct. But, they come on so the engine does not overheat.
Don't know if it is one or two fans that cycle though.
Old 06-15-2004, 05:52 PM   #6
Bakergtt
Member#: 59207
'05 X was 98 LGTT
both of mine will come on I know that. kinda strange that only one would come on. maybe only both come on if its really hot?? I know mine comes on around 89 degrees but thats cuz of my LINK software. Wierd thou
Old 06-16-2004, 09:52 AM   #7
White2.5GT
Member#: 25142
1998 Legacy 2.5GT
I have noticed lately that only one on mine comes on as well...I thought it was weird too....
White2.5GT is offline   Reply With Quote
Old 06-16-2004, 11:05 AM   #8
chahny
Member#: 42750
1995 Legacy Outback
Now 25% more Blue!
Construction is in full swing in the home of the NBA Champion Detroit Pistons, so I get stuck in some stop and go traffic. When I turn on the A/C, the driver's side fan cycles and the passenger side fan does nothing. My temp gauge doesn't budge, so I'm not worried about overheating yet. When I push the A/C button, the engine sounds like it has to work extremely hard to drive the compressor and the fan noise is very loud. This is an apples to oranges comparison, but in my old Honda the A/C would activate one fan constantly and the other fan would cycle.
I'll check the connections with a multimeter tonight. Does anyone know if there's a jumper to put the ECU in diagnostic mode like the WRX? From what I've read, WRX guys have a green connector under the dash, when jumpered turns on the CEL and cycles the fans.
Thanks for the replies.
Old 06-16-2004, 12:10 PM   #9
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
WRXes have that too...?
I know in OBDI cars (like mine), those connectors are for checking engine fault codes.
IronMonkeyL255 is offline   Reply With Quote
Old 06-16-2004, 12:17 PM   #10
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & 06 MCS
Its normal for just one fan to come on, and then if the car sits any longer you will see the other fan to start.
And I think you will have two black connectors, or two green ones. I know I have seen one green connector.
subiekid is offline   Reply With Quote
Old 06-16-2004, 10:27 PM   #11
chahny
Member#: 42750
1995 Legacy Outback
Now 25% more Blue!
Found the green connectors and hooked them up tonight. Long story very short, 20A fuse was blown so I replaced it. Voila! Both fans worky.
Thanks again!
For those curious about the green connectors, when shorted they display stored CEL codes and cycle both fans in parallel; off, low, high, etc.
Aftermarket FAL Radiator Fan Question 1WYDSTI Factory 2.5L Turbo Powertrain 9 06-30-2009 10:04 PM
A Few Final Radiator/Fan questions Twiztidunreal Electrical & Lighting 2 02-02-2009 07:02 PM
radiator fan question!!!!!!!!!PLEASE HELP ict-wrx Electrical & Lighting 6 08-30-2008 04:32 PM
AC + radiator fan question jblaine Service & Maintenance 6 03-21-2008 02:07 PM
radiator fan question exhondaguy Factory 2.0L Turbo Powertrain 3 06-20-2004 10:01 AM
Message Board Statistics All times are GMT -4. The time now is 06:01 PM.
