Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 06-15-2004, 04:31 PM   #1
PolTec Inc
Vendor
Vendor Sales Rating: (2)
Member#: 41768
Default End Links for: STi, WRX, RS and others, New Products Comming Soon
If you need end links, we got you covered. If you do not see what you need in here, just contact us (phone, email, PM) and we will see what we can do for you.
All end link sets include hardware and installation instructions.
For REAR END LINKS click here.
STi rear end links with spherical bearings that feature Teflon re-enforced liner and seals to protect them from elements, adjustable, made longer that stock to prevent sway bar flipping.
WRX aluminum rear end links with Teflon lined and sealed spherical bearings, heavy duty solid.
WRX aluminum rear end links with Teflon lined and sealed spherical bearings, heavy duty ADJUSTABLE.
For FRONT END LINKS click here.
STi and WRX Sedan steel front end links with Teflon re-enforced liner and seals, heavy duty adjustable. Those will fit all sway bars except the hollow ones, for special front end links that will fit the hollow sway bars give us a call or send an email.
RS and WRX Wagon aluminum front end links with Teflon liner and seals, heavy duty adjustable.
Why do we offer adjustable links? Because of tolerance stack up, both end of the sway bar do not always line up and by forcing the sway bar to align with the end links you are effectively loading your suspension and causing you car to tilted. Each 1/16 of an inch of misalignment equals to 20 lbs of unbalanced force on your suspension for the 24 mm sway bar. Using our adjustable end links you maj adjust the length of each end link to line it up with the sway bar as opposed to forcing it to fit.
We are also only company that uses seals in all of our spherical bearing. This offers you extra protection against dirt and water and keeps the bearings clean, properly lubricated and corrosion free so that the bearing remain smooth and will not become loose over time.
Soon we will also start offering aluminum adjustable lateral links for WRX and STi. They will be offered in few versions like: full pillow-ball (aka. spherical bearings) and with urethane bushings. We will also have Titanium lateral link later as well. I will post some pictures of prototypes later.
We also offer custom machining and development services, contact us with your needs.
Dariusz
PolTec Inc
708/308-0947
www.poltec.us
[email protected]
PolTec Inc is offline   Reply With Quote
Old 06-17-2004, 03:41 PM   #2
PolTec Inc
Vendor
Member#: 41768
For those with STi v.8 Pink 6-piece Lateral Links we offer a replacement adjustable end links with "boxes". A must for those with aftermarket sway bars. They are $165 + $10 S&H. Currently we have few sets in stock.
Old 06-20-2004, 07:54 PM   #3
PolTec Inc
Vendor
Member#: 41768
Bump
Old 06-21-2004, 11:07 PM   #4
BIGSKYWRX
Member Sales Rating: (102)
Member#: 7958
09 GH B+
Dariusz- couldn't v7 wagon/sedans use the "boxes" to upgrade to the adj spherical links? The STi lateral link kits use the same setup- you'd just have an empty bracket on your oem rear links- unless there isn't room????
Thanks
Mike
Old 06-22-2004, 11:01 AM   #5
PolTec Inc
Vendor
Member#: 41768
Mike,
There is a good chance that the "box" will interfere with the mount on the rear lateral links. I could, however, check if they will fit the stock lateral links and, since the mounts look very similar, this may give you some confidence whether they will or will not fit.
At the same time, and correct me if I am wrong, the v7 STi lateral links use the same end links as the stock WRX. So if you are looking for adjustable end links you might also want to consider our "C" shaped adjustable links for the WRX/RS (third pic in the first post). Those are a direct replacement for the stock WRX/RS end links.
In this case all you would be giving up is some flex in the lateral links bushing but you would be gaining slight weight saving since the WRX/RS adjustable end links are slightly lighter than the end links for v8 lateral links.
Let me know if you have further questions.
Regards
Dariusz
PolTec Inc
708/308-0947
www.poltec.us
[email protected]
Old 06-24-2004, 10:11 AM   #6
PolTec Inc
Vendor
Member#: 41768
We also offer sway bar collars that guarantee that your sway bar will remain centered and working properly. We have versions for any sway bar: front, rear, 20, 22, and 25 mm, hollow and solid, you will need to provide us with the actual sway bar diameter. Price is $35 if bought alone and $25 if you buy it with any end links.
Thank You
Dariusz
PolTec Inc
708/308-0947
www.poltec.us
[email protected]
Old 06-26-2004, 06:12 PM   #7
PolTec Inc
Vendor
Member#: 41768
Old 06-26-2004, 06:43 PM   #8
BIGSKYWRX
Member#: 7958
09 GH B+
Dariusz- are your non adj C shaped ones oem length- bolt hole to bolt hole?
Also reuse oe hardware (bolts)?
Thanks
Mike
Old 06-28-2004, 11:58 AM   #9
PolTec Inc
Vendor
Member#: 41768
Old 06-28-2004, 12:05 PM   #10
NBWRX
Member Sales Rating: (6)
Member#: 57256
2009 WRX wagon
Originally posted by PolTec Inc
The WRX/RS end links are about 1/2 inches shorter than the stock end links.
Why are you making them shorter?
NBWRX is offline   Reply With Quote
Old 06-28-2004, 02:41 PM   #11
PolTec Inc
Vendor
Member#: 41768
Shorter length gives you more clearance that lowered cars and/or cars with aftermarket mufflers might need.
Old 06-28-2004, 04:50 PM   #12
BIGSKYWRX
Member#: 7958
09 GH B+
Dariusz
How about the adjustable ones? I'm looking for stock length links as I frequent the gravel often and don't want as much independence left/right as possible.
Also is the hardware replaced the same size as the oem- I keep a limited amount of tools onboard and don't like to add to them (had to add a 13mm wrench because Noltec decided to use a different bolt on their tops ).
Thanks
Mike
Old 06-28-2004, 06:14 PM   #13
chudlo
Member Sales Rating: (17)
Member#: 15505
2002 JDMV8 STI Wagon
D is there any reason I couldn't use the STI (not the boxe ones) adj rear links on my wagon to sedan project? They are cheaper and stronger is why I am asking.
I will try to check tomorow morning for your answer, so that I can order them soon.
thanks,
chad in New Orleans
chudlo is offline   Reply With Quote
Old 06-28-2004, 07:13 PM   #14
PolTec Inc
Vendor
Member#: 41768
BIGSKYWRX,
Because our end links incorporate spherical bearings they will INCREASE effectiveness of your sway bar therefore they will make your suspension less independent.
chudlo,
As long as you use the rear lateral links from STi you should be fine with the STi end links but you will need STi sway bar as well. Call me if you want to discuss details.
Thank You
Dariusz
PolTec Inc
708/308-0947
www.poltec.us
[email protected]
Old 06-29-2004, 09:01 AM   #15
chudlo
Member#: 15505
Oh well, I tried.
I will be ordering the regular ones then.
thanks,
chudlo
PS: Can you PM me the shipping info. My internet will be down until Wed. Thanks again.
Old 06-29-2004, 09:44 PM   #16
mr. m
Member Sales Rating: (4)
Member#: 44229
2000 2.5 RS
blue ridge pearl
eta and approximate price on adjustable lateral links? will they fit on a gc rs?
mr. m is offline   Reply With Quote
Old 06-30-2004, 08:29 AM   #17
PolTec Inc
Vendor
Member#: 41768
Yes, we will have a version for this application that should become available within next week or 2. They will be approx. $280 for version with urethane bushings and $600 for full pillow ball version. Prices are per set of 4 lateral links.
chudlo,
You have a PM from me.
Old 06-30-2004, 03:14 PM   #18
chudlo
Member#: 15505
Cool
Got the PM, D.
Looking forward to installing the links!
Thanks,
chudlo
Old 07-02-2004, 04:27 PM   #19
PolTec Inc
Vendor
Member#: 41768
TTT
Old 07-05-2004, 06:08 PM   #20
PolTec Inc
Vendor
Member#: 41768
Old 07-06-2004, 01:35 PM   #21
chudlo
Member#: 15505
Thumbs up
I got my endlinks on Sat, bump.
Thanks.
Old 07-06-2004, 03:28 PM   #22
driggity
Member Sales Rating: (2)
Member#: 7453
2014 Scion FR-S
Hot Lava
Any update on the lateral links? Thanks
driggity is offline   Reply With Quote
Old 07-06-2004, 11:21 PM   #23
mr. m
Member#: 44229
2000 2.5 RS
blue ridge pearl
do you have pics of the sway bar collars installed? i cant figure out for sure where they go.
Old 07-07-2004, 06:26 PM   #24
PolTec Inc
Vendor
Member#: 41768
driggity,
I will have some pictures of the final product this weekend and then I will give you more details.
Thanks
D
Old 07-07-2004, 09:05 PM   #25
mr. m
Member#: 44229
2000 2.5 RS
blue ridge pearl
thanks. thats where i was thinking they went but i wasnt sure.
Whiteline Rear End Links KLC066 08+ WRX/STI, 07+ Forester Brand New b16h22 Suspension/Brakes/Handling 6 06-02-2010 01:07 AM
NC: EJ20 wrx engine, and other parts soon... 03SubaWRX Private 'For Sale' Classifieds 8 11-27-2005 12:20 PM
NC: EJ20 wrx engine, and other parts soon... 03SubaWRX South East Region Forum 9 11-17-2005 01:39 PM
Want to buy front and rear sway bar for 05 wrx, front and rear end links for 05 wrx mrtrex Private 'Wanted' Classifieds 3 08-26-2005 09:25 AM
End-Links for any Subaru - STi, WRX, Legacy and Forester, Adjustable Lateral Links PolTec Inc Suspension/Brakes/Handling 34 12-01-2004 11:53 PM
