Old 06-16-2004, 01:11 AM   #1
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
Resurected and Swapped
Default 2.5 Heads
anywhere else to get good heads, beside cobb. if i get cobb heads they'll cost more than my stage 2 sti shortblock. would it be worht it to just take my sohc heads to payne or somewhere and have them done up? oh and am i right in saying the sohc heads will fit fine on an sti block except for the coolant passages being slightly off?- IC
IdenityCrisis is offline   Reply With Quote
Old 06-16-2004, 03:52 AM   #2
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
bump for any info. and yes i've been searching for info i just would like peoples opinion. - IC
Old 06-16-2004, 03:57 AM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
correct
Old 06-16-2004, 03:58 AM   #4
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
I would go with twe they are up in canada. I have heard good things about them over cobb. Nothing bad against cobb except they take a while to get your parts to you. Worth checking out.
speed_freak27 is offline   Reply With Quote
Old 06-16-2004, 07:05 AM   #5
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
i was looking inot them, i just dont get why heads cost about the same as a sti shortblock. - IC
Old 06-16-2004, 11:43 PM   #6
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
the coolent passages aren't off.. You just need to use sti head gaskets. If they were off I didn't notice.
Pi7467mp is offline   Reply With Quote
Old 06-17-2004, 02:09 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
Most of your power is made in the heads......that's why they are expensive.....
Jay Storm
Old 06-17-2004, 04:13 AM   #8
IdenityCrisis
Member#: 55007
2000 RSti SilvEaton
yeah, i hope most of the power is in the heads for the amount of money some are charging. i'm gunna stick with building my stock heads. i'm porting and polishing them. giving them a multiangle valve job, twe titanium springs and retainers and twe stage 2 cams. - IC
Old 06-17-2004, 05:19 AM   #9
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
IC that's the way I'm gonna be going if I can find a spare set of heads cheap enough. Keep in mind that all that work will put you close in $ range to an already completed head.
Would DOHC NA 2.5 heads work with STi 2.5 block? 2slofouru Subaru Conversions 11 02-21-2007 01:04 PM
pic of 2.5 head gasket on 2.2 head JoshP Normally Aspirated Powertrain 9 06-24-2006 01:26 AM
2.5 heads on a 2.2? Impreza25RS Normally Aspirated with bolt-on Forced Induction Powertrain 6 02-07-2002 05:59 AM
99 2.2 vs 2.5 heads on EJ22t block mikeje Normally Aspirated with bolt-on Forced Induction Powertrain 4 10-21-2001 12:28 AM
2.5 heads on a 2.2 iceman Technical Forum Archive 8 06-20-2000 09:09 AM
