Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 06-16-2004, 10:12 AM   #1
GRNMTNRS
Member#: 7607
04 forester
red granite
Default OEM boost gauge install issue.
I have just installed the oem gauge, and am not sure why I am only making .05 mpa max.
I have the vac line running off the stock BOV, and I shortened the line a little because it seemed long by 3 or so inches. I purchased it used, so the original T connection was not included. I am using a T from napa that is designed for windshield washers. Is this the problem?
The vacum seems to be reading correctly @ -.05 to -.07. I followed the factory install instructions, and the car seems to pull fine. If it is the T were can I get the correct one?
Please help...
Thanks in Advance, and Happy Motoring...
GRNMTNRS is offline   Reply With Quote
Old 06-16-2004, 10:18 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Did you or were the vac lines to the turbo ever messed with????
like with an MBC....mebbe....??? If so, they may be bass ackwards
Sounds like wastegate spring boost pressure, to me.
Uncle Scotty is online now   Reply With Quote
Old 06-16-2004, 10:49 AM   #3
GRNMTNRS
Member#: 7607
04 forester
red granite
I have it running to the correct location though right?
There was never a mbc on the car, but I will check all the lines off the turbo. Is it possible that when I installed my MRT turbo back w/ divorced wastegate that this is causing problems...
Stewart Warner Boost gauge install issues . o 69 o . Interior & Exterior Modification 0 06-20-2007 03:39 PM
That "T" part for the oem boost gauge install uathatis Private 'Wanted' Classifieds 3 07-29-2006 11:17 AM
oem boost gauge install question Caelaorn Newbies & FAQs 6 03-26-2006 03:35 PM
autometer boost gauge install issues Nick W Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-19-2003 11:40 AM
OEM boost gauge install - question WRXVII Service & Maintenance 6 12-08-2002 03:51 PM
