Old 02-14-2001, 12:29 AM   #1
Derres Catalano
Member#: 3244
2000 2.5 RS
Silverthorn
Post UD pulley or light weight stock size pulley?
I know that JC SPorts is selling pulleys for cheap right now, but which one is better? You would think that the UD pulley would give you more power (5-6 hp), but what do you get outta the light weight stock size pulley? Better throttle response? Which is better?
Also, I read somewhere about a crank pulley, I forget who sells it. But it is supposed to be UD as well, but for race applications. If there are benefits from a stock size pulley that is light weight, does anybody make a light weight crank pulley (stock size)?
Derres Catalano is offline   Reply With Quote
Old 02-14-2001, 12:56 AM   #2
Julian
Member#: 1182
MY00 RS
BRP
Post
Some people have claimed improvements after the UD pulley was installed. Some people (*cough* Brucelee *cough*) have claimed otherwise. When you think about it, while the flat-four motor has less rotating mass, there's still a decent amount of weight rotating inside the block. What's a few pounds?
A non-related example: My other car's stock flywheel weighs 30 lbs. I replaced it with a 20lb. unit. I haven't noticed much (read: no) difference. Sure, I lightened the flywheel by 1/3, but compared with the total rotational mass, it wasn't a very big percentage, hence produced nothing much in the way of gains.
$150 (or so) for a pulley could get you a nice set of brake pads. One good tire End links...
Julian
Julian is offline   Reply With Quote
can a lightweight stock size pulley unbalance your crankshaft? backstrom2.5 Normally Aspirated Powertrain 2 05-15-2008 12:27 AM
Ebay Light-Weight/Underdriven Engine Pulley? tigerrider11 Normally Aspirated Powertrain 17 12-21-2007 09:40 AM
light weight flywheel and pulleys. thoughts please Waking The Fallen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-19-2006 10:27 AM
stock sized pulley a good idea for a cobb stage 2 wrx? garie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 10-17-2004 06:15 PM
lightweight crank pulley with harmonic dampner, stock size CrowbarKen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 02-11-2003 11:32 AM
