Old 02-13-2001, 10:26 AM   #1
jacktam1
Member#: 1783
2000 2.5RS
Question Bore the throttle body..
Who has experienced in bore the throttle body? any difference and performance gain?
jacktam1 is offline   Reply With Quote
Old 02-13-2001, 10:29 AM   #2
grimlock
Member#: 2683
2011 STi 5-Door
Post
Trey Cobb from Cobb Tuning ( www.cobbtuning.com ) sells extrude honed throttle bodies, but they're only really effective for FI applications otherwise, the bottleneck is probably somewhere else.
Ross N.
grimlock is offline   Reply With Quote
Old 02-13-2001, 10:31 AM   #3
rbehny
Member#: 1908
Post
Uh...Cobb tunning has a bored throttle body and they advertise a 20% air flow gain over stock. So unless you are getting it custom made i would say go with cobb.
rbehny is offline   Reply With Quote
Old 02-13-2001, 10:37 AM   #4
jacktam1
Member#: 1783
2000 2.5RS
Post
I am gonna do it at local today, but I just wonder is it useful..
I visited tray's site, but he said it's recommend doing this modification to a car that's already sufficiently modified, but what is "sufficiently modified"?
MY00 has intake,muffler,pulley,ITC,AFC,Plugs and plug wires.
Old 02-13-2001, 10:59 AM   #5
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
& 08 Triumph Speed Triple
Post
if you have a local guy do it make sure the inside surface is nice and smooth and that he provides a new throttle butterfly that compensated for the larger opening. Other things can also increase the flow, like design of the butterfly and the throttle shaft inside the opening. Make sure the gasket is matched to the new bore as well. Your gains will be small at best, a hp or 2. This mostly helps with your mods plus headers, head work, cams, higher compression, and a extrude honed intake manifold.
Josh
[This message has been edited by scoobiejosh (edited February 13, 2001).]
scoobiejosh is offline   Reply With Quote
please help, need the hose that goes from the intercooler to the throttle body wrxracer55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-06-2003 02:09 PM
WTB STi red rubber hose from the IC to the throttle body JDM addict Private 'Wanted' Classifieds 0 09-22-2003 03:29 PM
Bored out throttle body Deznuts05 Normally Aspirated Powertrain 9 03-21-2003 05:29 PM
Anyone bore out the throttle body? phatride01 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 09-26-2002 05:54 PM
Bored out Throttle body what else is needed for performance gain? rbehny Normally Aspirated Powertrain 9 08-30-2001 08:04 PM
