Old 02-13-2001, 07:05 AM   #1
fellfrosch7
Member#: 2389
'98 Impreza L Wagon
'90 Talon TSi AWD
Post Silly turbo question for ya...
OK, I've seen turbo cars that have a cold-air intake. How does that work? When the turbo isn't spooled up, is there some additional piping that acts as a normal intake? And when you add a cold-air intake, does that feed the engine only when the turbo isn't spooled up, or does the cold air go into the turbo as well as just the non-boost intake? This is if I'm correct in assuming two different intakes, one for off-boost and one with boost. If I'm wrong, please enlighten me.
fellfrosch7 is offline   Reply With Quote
Old 02-13-2001, 07:17 AM   #2
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
& 08 Triumph Speed Triple
Smile
No there is only 1 intake. The colder the air the denser, weather you have turbo or not.
Josh
scoobiejosh is offline   Reply With Quote
Old 02-13-2001, 07:19 AM   #3
Damon
Member#: 2902
89 gmc work truck
08 jeep rubicon unlimited
Post
your not gonna have 2 different intakes. here is how the setup goes..
you have your turbo. its connected to the exhaust manifold. there is a pipe going from the turbo around to a intercooler, and back into the intake manifold. your intake connects somewhere inbetween where the intercooler and intake manifold is. (please correct me if im wrong guys. this is what i remember from my readings)
Damon is offline   Reply With Quote
Old 02-13-2001, 07:44 AM   #4
shimstock
Member#: 3002
Post
here's a ince little diagram for ya Rafal
http://members.fortunecity.com/spasm.../how/turbo.htm
shimstock is offline   Reply With Quote
Old 02-13-2001, 07:48 AM   #5
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
Post
actually... the intake is connected to the turbo. Two sides to the turbo, the turbine and the compressor. The turbine side is connected to the exhaust. On one side is the exhaust manifold where hot exhaust gases come in, and spin the turbine and exit the other side to the cat/exhaustpipe and out of the car. The compressor side is connected to the turbine so that when it spins, the compressor compresses fresh air from the intake side, pushes it thru the other side to the intercooler and into the engine
...basically... usually the exhaust isn't fast enough on its own so the turbo decreases the radius of travel into the center of the turbine to speed it up... and then there are things like MAF/MAP's, BOV's, wastegates, and other bits, but the total basic route of air is intake to turbo to I/C to throttle body to cylendar where it is burned to exhaust manifold to turbo and out of the car
mrbell is offline   Reply With Quote
Going to wax my baby for the 1st time. question for ya Super_HKS Car Care & Detailing 12 09-03-2008 05:52 PM
Here is a real fast Turbo car for ya (no suby here) turbowagon02 Member's Car Gallery 17 05-01-2007 09:43 AM
Question For Ya ? scooter2 North West Impreza Club Forum -- NWIC 1 06-14-2001 11:58 AM
mpaone - question for ya mpaone South East Region Forum 3 04-07-2001 12:40 AM
Attn: Joe z tire question for ya. bill harvey New England Impreza Club Forum -- NESIC 8 03-19-2001 08:30 PM
Message Board Statistics All times are GMT -4. The time now is 12:16 AM.
