#1 |
Member#: 3056
Vehicle:2001 Impreza 2.5RS Blue Ridge Pearl |
How much power can you squeeze out of a normally aspirated SOHC 2.5 litre engine? New intake and manifold, cams, exhaust and various other items would be required, but I'd like to know what kind of power is available without adding nitrous/blower/turbo set up? Also, what would driveability be like? Gutless on the bottom end and a screamer in the upper revs?
#2 |
Member#: 989
Vehicle:99 RS Graphite Gray Pearl |
it really depends on how much are you willing to spend on the setup.
you should be in the 200-210 with header, exhuast, ud pulley, intake, and a programable ecu (tec II, haltch,....) laters michael ps: with the programable ecu you need to tune in right for the best performance too. |
#3 |
Member#: 3409
NWIC
Vehicle:1998 Ram 2500 Green. |
Is the programmable ecu something you have to monkey with all the time? Or can you just set it (pay someone else to set it right) and leave it?
#4 |
Member#: 1140
SCIC
Vehicle:2013 Ecoboost'd F150 Grey |
It all depends on which one. they get fairly pricy.
#5 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
The Tec-II can be tuned properly, then it can be left alone. I don't think any of the programmable ECU's require constant tinkering. It just takes a lot of effort to get them to the non-tinkering stage.
I _think_ jun racing has done development on an NA EJ25 and has a rumoured 300hp, but this is unconfirmed AFAIK. Trey Cobb of Cobb Tuning has his RS running at approximate 220hp at the flywheel, but that is speculative. He has dyno results somewhere if you do a search. He had P&P heads, E&H intake manifold, P&P throttle body, upped compression to 10.5:1, borla headers and exhaust, intake (not sure), na stage 2 cams, and Haltec ECU. |
#6 |
Member#: 2112
13's...stay tuned
#7 |
Member#: 989
the programable ecu that i know
haltech you can have or save a few settings. setting that you have tune to suit your needs. but of course you will need to carry a labtop computer around inorder to tune the car. hope this helps michael |
| Thread Tools | |
| Display Modes | |
| 2.5 litre sti heads (fully built) 2.5 crank, AVCS cam gears | 700hp | Engine/Power/Exhaust | 7 | 11-24-2007 02:37 PM |
| 2.5 Litre compared to 2.0 Litre | Special | Built Motor Discussion | 8 | 09-13-2007 12:34 AM |
| Subaru 2.5-Litre Turbo Boxer Engine wins 2006 International Engine Of The Year Award | Paraskass | General Community | 12 | 07-30-2006 06:38 PM |
| 2.5 Litre wins 2006 engine of the year award | kwycstix | News & Rumors | 4 | 06-13-2006 03:16 PM |
| Forester 2.5 Litre Turbo 2004 late apperance | imprezawd | Forester Forum | 31 | 01-24-2003 10:08 AM |
