Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 02-12-2001, 11:54 AM   #1
ninetalesnwf
Member#: 3739
85 R30 skylineGT-T
Red/black
Post MAX hp of EJ20
what is the max HP you can produce on the EJ20 engine, with mods
thanks
ninetalesnwf is offline   Reply With Quote
Old 02-12-2001, 02:27 PM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
There was a fairly large discussion on this recently. Try doing a search. I think Simon from Prodrive stated that anything over 280hp in stock form will cause problems. A fully tuned motor is capable of more, but there is no set MAX hp limit. After a certain amount of power, your performance becomes hampered by other mechanical items such as axles, transmissions, etc.
<IMG SRC="http://www.autospeed.com/site/autospeed//images/0579_17hi.jpg" border=0>
That is the Tony Rigoli Performance WRX that just recently ran a 10.04 1/4mi.
[EDIT] I forgot to mention that this WRX is stroked to ~2.2L
[This message has been edited by stimpy (edited February 12, 2001).]
Old 02-12-2001, 05:35 PM   #3
dunny
Member#: 4115
2002 Impreza WRX
Post
How would the max output of the Ej22T compare to the 20 if it had the RS or some other head?
dunny is offline   Reply With Quote
Old 02-13-2001, 12:13 AM   #4
Lix
Member#: 1560
Post
That's a tough quesiton to answer since people are always finding new ways to generate hp.
I guess if you wanted MAX hp, then find a thermodynamics book, look up the Otto Cycle and fill in the variables and solve for work output. This would be the MAX hp you can make with the engine, which in the real world will be less due to things like friction. With infinite money and technology, you should get close to this number.
Lix is offline   Reply With Quote
Old 02-13-2001, 12:16 AM   #5
ninetalesnwf
Member#: 3739
85 R30 skylineGT-T
Red/black
Post
thanks alot
Old 02-13-2001, 12:20 AM   #6
Lix
Member#: 1560
Post
np
I think MRT has a car pumping about 450 hp from the EJ20. Don't quote me on this though.
Felix
Max HP of a V1 or V2? EcksJay Subaru Conversions 14 10-24-2005 09:10 AM
Max Horsepower on EJ20 open deck block with upgraded internal? AXA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 12-16-2004 01:11 AM
ej20 max hp b00st3d Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-01-2002 09:21 AM
15,300 max hp! SubieRacer General Forum Archive 21 01-28-2001 10:48 AM
max hp of current WRX turbo (some questions) copec Normally Aspirated Powertrain 2 01-02-2001 04:42 PM
