Welcome to the North American Subaru Impreza Owners Club Wednesday July 30, 2014
Old 02-02-2001, 12:55 AM   #1
8Complex
Member#: 922
04 FXT
Red
Post Stock ECU with lowered compression?
Seems to me that it doesn't sound like it'll work right. I can't figure if it'd end up lean or rich, though...
Old 02-02-2001, 05:20 AM   #2
Memnoch
Guest
Member#:
Post
I would think it'd end up too rich. Since with higher compression you always have to richen up the mix to avoid detonation.
That's all that comes to mind, and most likely it's wrong too
Old 02-02-2001, 06:51 AM   #3
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
& 08 Triumph Speed Triple
Post
I would think richer. With lower compression the combustion isnt as efficient. And it might injest less air. I dont know how MAF or MAP would deal with that, not practical experience. Usualy when someone lowers the compression they do other things like add a turbo or turn up the boost, so there are too many variables at once to narrow one down.
Josh
scoobiejosh is offline   Reply With Quote
Old 02-02-2001, 07:34 AM   #4
svxtrem
Member#: 1008
2006 STI
Steel Grey Metallic
Post
Neither. The compression ratio doesn't affect the mixture. It will affect the need for timing. A lower compression ratio will require more total timing due to the larger volume of the combustion chamber. A lower compression ratio will also lower the thermal efficiency. This is the correct approach if you are going to add a turbo, but definitely not for N/A.
svxtrem is offline   Reply With Quote
Old 02-02-2001, 09:05 AM   #5
8Complex
Member#: 922
04 FXT
Red
Post
Yeah, turbo in the near future, but I figured if I ended up having to have the short block replaced (piston slap) that it'd be an ideal time to slip a few luxuries in.
Old 02-02-2001, 09:27 AM   #6
Memnoch
Guest
Member#:
Thumbs up
Thanks svxtrem, I knew I had my head up my ass
Old 02-02-2001, 09:37 AM   #7
8Complex
Member#: 922
04 FXT
Red
Post
I just talked to Trey Cobb about it and he said that it would run fine, but like it was a bit old and worn. If I wanted to correct for some of the power back, I'd need to have an ITC to correct the timing. He also mentioned that I'd want to flush the system of carbon build-ups before I installed the turbo (which I'm not entirely sure how to do... spray a mist of water so that it it'd intake it and do soms steam cleaning?).
Old 02-02-2001, 06:09 PM   #8
98mpreziveRS
Member#: 972
Post
Umm..nick please do not do that..lol
they make cleaners meant for that...so do yourself and your motor a favour and get the right tool for the job (and don't hydrolock your motor in the process )
98mpreziveRS is offline   Reply With Quote
Running stock ecu with turbo motor ?'s serious Engine Management & Tuning 3 04-19-2013 10:01 PM
stock block with high compression pistons what do you guy's think? spoolinsti05 Built Motor Discussion 6 05-31-2009 03:06 AM
stock ecu with fuel rails Fountainpower Engine Management & Tuning 0 06-22-2005 10:23 PM
Lower Octane better with lower compression ... makofoto Factory 2.0L Turbo Powertrain 22 03-13-2005 11:20 AM
Is it safe to use stock ECU with up-pipe and turbo back exhaust (1 cat)? gtr Factory 2.0L Turbo Powertrain 6 09-11-2001 08:32 AM
