Old 02-11-2001, 03:54 PM   #1
CO Sube
Member#: 4138
Question TEC - II on an N/A motor
Is there any benefit to adding a TEC-II to a mildly modified N/A RS? Would changing the cams make the computer any more useful?
Casey
CO Sube is offline   Reply With Quote
Old 02-11-2001, 05:07 PM   #2
cvalle-sd
Member#: 420
2001 Cr-V
Post
Just ask Kartboy - He's got a '99 w/a tec II. It'll have a turbo really soon, but it is pretty fast already. Good if you plan on a future turbo upgrade, and want to split the cost up, and learn to program the thing before boost becomes a factor.
cvalle-sd is offline   Reply With Quote
Old 02-11-2001, 05:33 PM   #3
Member#: 67
1999 Outlasting
the competition.
Post
What he said.
[email protected]
Old 02-11-2001, 07:58 PM   #4
Overtime
Member#: 1346
Post
If you built your EJ25 up so as to require (or at least strongly suggest ) a higher rev limiter, the TEC-II would be very ideal. However, for strictly bolt-ons, you're looking at $3000 for 15-20hp according to NickCat and the others who have tried that route. Not a good deal.
Overtime is offline   Reply With Quote
Old 02-11-2001, 08:43 PM   #5
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
I thought Shiv's selling price for a NA tek II was $2000.
That 10-15 hp increase is strictly from advancing the timing to take advantage of higher octane gas. There are cheaper ways of doing it, like the Apexi ITC, but the Tek II is the easiest.
Revision is offline   Reply With Quote
Old 02-11-2001, 10:34 PM   #6
CO Sube
Member#: 4138
Question
I have already changed the intake, fuel pump and a JC Sports torque chip. I plan to do exhaust and cams. What kind of gains would I likely see with these mods? Does the torque chip essentially do the same thing as the TEC-II?
Casey
Old 02-11-2001, 11:22 PM   #7
shiv
Member#: 607
Post
CO Sube-- The TEC-II is a fully programmable EFI system capable of controlling (and making the best) of virtually any engine, modified or not. In terms of function/forum/cost/etc, it doesn't shares much in common with the torque chip.
Overtime-- The price for the NA TEC-II kit is $1950, not $3000
Cheers,
shiv
shiv is offline   Reply With Quote
Old 02-12-2001, 07:56 AM   #8
cvalle-sd
Member#: 420
2001 Cr-V
Post
Just based on financial reasons - Cobb cams and a Vishnu N/A TecII make a real alternative to a turbo kit. Again, you can do the two separately and get a performance boost w/each step. I have an AFC and ITC already, so I don't know if I'll go the TEC II route if I don't also "blow it", but the cams are a likely purchase - the TECII would really be able to exploit them, I'm sure.
Old 02-12-2001, 10:37 AM   #9
Overtime
Member#: 1346
Post
I was a little off.
Shiv-has anyone programmed the TEC-II on a built EJ25 yet? (ie cams, heads, maybe higher CR, etc.)
BTW, I thought the torque chip was just a little fuel-richener. No?
Old 02-12-2001, 02:37 PM   #10
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
This case uses a different ECU, (I know I know) but I feel it kind of helps. Trey Cobb of Cobb Tuning is running cams, heads, TB, headers, exhaust, and Halteck E6k ecu and he was predicting about 220hp at the flywheel. The power is coming from a combination of all modifications including an aftermarket ECU. With a different ECU, you are adding a margin of safety as well as customizing your fuel/ignition to work perfectly with you mods.
I don't know if I just confused the thread or helped, but there it is.
Old 02-12-2001, 03:10 PM   #11
CO Sube
Member#: 4138
Question
I am fairly mechanically inclined, but have little automotive experience. Would that make an ecu like this a bad idea? What are the major differences between the TEC-II and the haltek?
CO Sube
Old 02-12-2001, 03:16 PM   #12
CO Sube
Member#: 4138
Post
I'm not sure exactly how the torque chip works, but my limited understanding of it is that it is a self-learning fuel-richener and plays with the ignition timing to some extent. The main problem is that you can't program it, it does it on it's own over time.
Old 02-12-2001, 03:51 PM   #13
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
I don't want to turn this thread into a Tec II vs The World, but I think the Tec's largest selling point is the high resolution sensors (specifically the crank position sensor). Just about any aftermarket ECU is going to provide you with the ability to tune your car to drive the way you want it to. The torque chips are self contained probably using some sort of logic to determine optimum fuel curve. IMHO no amount of logic (algorithim) research is going to be better than human intervention.
[This message has been edited by stimpy (edited February 12, 2001).]
Tec II on a WRX dch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-29-2001 12:30 AM
Report: TEC-II on a MY00 jhuang76 Technical Forum Archive 4 08-12-2000 01:21 AM
SHIV Tec II on another car !? jdchmiel General Forum Archive 1 06-22-2000 06:54 PM
TEC II Update. Thoughts on NA TEC II Kit installation. Imprezer Technical Forum Archive 30 05-26-2000 08:37 PM
TEC-II / TEC-II Connection Port STi Sev Technical Forum Archive 10 05-25-2000 07:28 PM
