Old 10-21-2000, 01:22 AM   #1
Digital_Boy
Member#: 730
Question Recommendations for a turbo prepped EJ25 block?
As you might have guessed from my post on the classifieds, I am cutting the BS and getting the ball rolling.
What would constitute a turbo prepped shortblock?
I know that forged pistons and forged con rods are a necessity, but what about the crankshaft? Is the stocker forged, and will it hold up to a high boost street engine?
What about rings? Gapless? How much would a pre-prepped block run? Would the cost differential of kit vs pre assembled be great enough to warrant me putting the pieces together? I do have experience pulling engines apart and putting them back together, so I could conceivably do the assembly on my own.
I want to know the score before I commit a large sum of money to engine, internals, turbo, ECU, and so forth. I want to get everything up front so I don't end up dragging it out and blowing the budget because I had to do a half assed job to get it running, and go back and do a portion of the build over again.
Digital_Boy is offline   Reply With Quote
Old 10-21-2000, 01:24 AM   #2
TMR Impreza
Member#: 168
2011 M3 and STI
white
Talking
ISR is building my motor. Ed has some tricks up his sleeve. Should be a nice motor.
www.autocarsubaru.com
TMR Impreza is online now   Reply With Quote
Old 10-21-2000, 02:54 AM   #3
Joel Gat, 1.8L
Member#: 32
Post
Hello,
Trey Cobb can also prep an engine. He works over the blocks, seals the deck, adds the piston backside oil-squirters, bores and hones the block to 100mm (if you want), has forged pistons, 8.5:1 or whatever custom CR you want, etc.
www.cobbtuning.com
Joel
Joel Gat, 1.8L is offline   Reply With Quote
Old 10-21-2000, 07:50 AM   #4
legacyGT00
Member#: 2052
Question
TMR, there was a typo in your link http://www.autocaresubaru.com.
Anyway, I checked it out. Are you getting a turbo? Which?
legacyGT00 is offline   Reply With Quote
Old 10-21-2000, 10:25 AM   #5
Tim Prudence
Member#: 216
Post
What is your target horsepower/torque?
Tim Prudence is offline   Reply With Quote
Old 10-21-2000, 10:46 AM   #6
Digital_Boy
Member#: 730
Post
Tim, my target is in the 350-400 range, possibly 450. I've seen that it can be done reliably (by that I mean 100K mile reliably) if you select the right components and follow good assembly guidelines.
Old 10-21-2000, 10:36 PM   #7
markus
Member#: 438
2004 STi
White on Gold
Post
IIRC, the EJ25 crank is a cast piece. Not sure if you can get 100k reliability at those sort of HP levels.
However, that point may be moot since it appears that a lot of people that are going FI on their EJ25's are having tranny problems long before engine reliability problems.
My 2cents
markus is offline   Reply With Quote
Old 10-21-2000, 11:51 PM   #8
Digital_Boy
Member#: 730
Post
Markus,
I am *well* aware of the stock RS transmissions tendency to grind 2nd gear to mulch under spirited driving with a turbo. I have contacted a company that makes 450HP capable *HELICAL* (i.e. synchromesh capable) gearsets for the Subaru. So, no dog box in my future.
Old 10-22-2000, 01:10 PM   #9
Jay_UK
Member#: 296
Post
Ideally:
Crank
Rods
Pistons
Uprated main bearings
For that power you wont need to brace the block or go closed deck.
I might even go as far as saying the stock crank would be ok.. but will need balancing...relieving...etc..
But definately do the rods and pistons..
As for compression... I would go for 9.5'ish.. but will depend on fuel and final boost..(simply put)
J.
ps - Ready to be corrected..as per usual
Jay_UK is offline   Reply With Quote
Old 12-19-2000, 01:46 PM   #10
MikeYOX
Member#: 1754
2002 S4
Nogaro Blue
Question
What company is that digital_boy? How much are the gears?
MikeYOX is offline   Reply With Quote
Old 12-19-2000, 02:41 PM   #11
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
You might also want to inquire about this sort of thing to www.b-specusa.com .
Old 12-19-2000, 02:54 PM   #12
Turk
Member#: 1888
Post
Beat me to it Stimpy www.b-specusa.com has a stronger crank and other goodies and www.cobbtuning.com has everything else you need.
Oh yeah please share the knowledge about the transmission.
Turk
Turk is offline   Reply With Quote
Old 12-20-2000, 05:47 AM   #13
Marquis
Member#: 64
1999 Impreza 2.5RS
Rally Blue Pearl
Post
Digital_Boy, I can't recommend you building the shortblock yourself. The rest you can probably do without really hampering engine reliability(though you may want to have someone assemble the heads, too), but unless you consider yourself an expert engine builder let someone else do it. You're talking about a lot of horsepower out of an engine you expect to last for awhile. In this respect, there is no substitute for an extremely profesionally built shortblock.
Marquis is offline   Reply With Quote
WTB: Turbo or non turbo EJ25 block & crank bugeyes Private 'Wanted' Classifieds 0 12-30-2006 03:41 AM
What intake recommended for stock turbo and rotated setup? Deranged Factory 2.5L Turbo Powertrain 4 11-05-2006 09:36 PM
Recommendation for Quite Turbo-back Exhaust lightpost12 Factory 2.0L Turbo Powertrain 28 05-14-2006 06:30 PM
Fueling recommendations for small turbo upgrade?? BigJ04STi Factory 2.5L Turbo Powertrain 5 01-30-2006 02:32 PM
ej25 block, sleeving to 2.2L size for turbo?? erice1984 Subaru Conversions 4 12-31-2004 11:32 AM
Message Board Statistics All times are GMT -4. The time now is 11:45 PM.
