Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 06-18-2004, 12:37 PM   #1
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Default Idle screw
Just had a few questions where the hell this screw is located to adjust the amount of air entering the manifold at idle. Is it actually inside the throttle body? Or is it actually inside the IAC solenoid? Anybody got pics or anything to point in the right direction because I'm not in the mood to shell out 250 bucks for a new solenoid to find out it ain't that. Thanks and any help would be appreciated.
Benny
benjaminetanyahoo is offline   Reply With Quote
Old 06-18-2004, 06:31 PM   #2
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
Not sure if this is the same for all imprezas. But on my car there's a small phillips screw that's right by the throttle cables just below the throttlebody, locked by an 8mm nut. Loosen the nut and turn the screw to raise or lower your idle rpm.
cRayZee is offline   Reply With Quote
Old 06-18-2004, 07:12 PM   #3
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
I'll check it out, see what happens, is there some kind of marker or something that says where it should originally be at?
Old 06-18-2004, 11:22 PM   #4
kaos200
Member#: 2692
theres no standard spot. It is very touchy though, a small turn makes a big difference.
kaos200 is offline   Reply With Quote
Old 06-19-2004, 03:36 AM   #5
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
You aren't supposed to change the idle rpm It's set be the ecu, and the ecu will sert it correctly.
THAWA is offline   Reply With Quote
Old 06-19-2004, 12:02 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Dude, try a junkyard for an IAC... or ask here on the board. $250 is a ripoff.
The idle screw is always in the same place on every car... it is used as a stop on the throttle cable pulley on the throttle body. There is a little right angle at the side it stops on, and the screw is behind that, in another bracket. It's very hard to get to, and very hard to adjust as even a teeny tiny turn will make drastic changes. You really aren't supposed to play with it.
Old 06-19-2004, 12:10 PM   #7
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
Yeah I have a intake manifold and throttle body coming in and I'm getting the IAC off of that. If that doesn't fix it then I might just give the idle screw a try. What bugs me is that sometimes, well very rarely it will idle fine in traffic normally after 30 minutes of driving.
Another thing I noticed was if I apply the brakes while idling it effects the idle along with me turning the wheel. If I'm at a light and I make almost a full rotation of the wheel while stopping, idle returns normal for 30 seconds and down it goes again.
Very interesting symptoms, but hopefully this IAC solenoid will do the trick.
Thanks everybody
Old 06-19-2004, 12:15 PM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Very commonly if you have an issue with a MY00-01 RS idling or running a little funny, it's a front O2 sensor. Are you throwing any CE lights or anything?
Also, just taking a stab since I don't know what year your car is...
Old 06-19-2004, 12:32 PM   #9
benjaminetanyahoo
Member#: 41300
2000 New York
MTA
It's a 2002, and I just replaced my front 02 sensor. It has improved my gas mileage and my hesitation while driving, but nothing with idle.
Old 06-19-2004, 12:42 PM   #10
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Hmmmm... the O2's should be the same front O2 sensor, but I'm not sure what else would cause your problem. Does a good ECU reset help at all?
where is the idle screw? homer09 Normally Aspirated Powertrain 4 09-05-2007 02:26 AM
screwed idle. Impr3zy0u Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-28-2005 11:32 AM
HELP!!! Screwed up idle after clutch install! BenBortner Normally Aspirated Powertrain 10 06-20-2005 11:56 AM
HELP!!! Screwed up idle after clutch install! BenBortner North West Impreza Club Forum -- NWIC 1 06-19-2005 07:15 PM
Where is/ or is there an idle adjustment screw for 02' Wrx? PaulRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-14-2003 07:19 PM
