Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 02-02-2001, 04:31 PM   #1
Tensecgn
Member#: 2102
Post 2.5l short block with 2.2l heads
I`m trying to put together a package.This is what i have.I have a 2.5l shortblock and i want to put on a set of 2.2l heads because that is what i have to work with.The heads are already ported.What i need to know is will the flywheel,and all the pulleys fit the 2.5 shortblock.The motor will be going in a 1990 legacy that is turbocharged by a t3 turbo running 15psi.It also has an intercooler.
Tony
Tensecgn is offline   Reply With Quote
Old 02-02-2001, 04:40 PM   #2
ins8ibl
Member#: 2196
Post
This setup would probaby raise your compression quite a bit which would be a bad thing for a turbo engine. I would suggest using the thickest head gasket you can get to lower the compression ratio. I think paeco sells thick dead soft reusable copper head gaskets if that helps.
ins8ibl is offline   Reply With Quote
Old 02-02-2001, 05:06 PM   #3
Aspen
Member#: 145
Banned to
Housework for Summer
Post
The flywheel and pulley are the same between the 2.2L and 2.5L NA motors.
Aspen is offline   Reply With Quote
2.5 short block with 2.2 heads? Zero92828 Normally Aspirated Powertrain 7 05-02-2009 05:22 PM
WTB 2.5L short block / long block ibanez24_7 Private 'Wanted' Classifieds 5 02-14-2009 09:14 PM
Axis Racing Stage 3 2.5l short block with GT35R lazzy8oy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 02-05-2006 02:33 AM
Interesting tid bit on Sti 2.5L short block IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-26-2003 12:10 PM
2.5L short block Tensecgn Normally Aspirated Powertrain 0 11-30-2000 05:14 PM
