Old 02-02-2001, 12:30 PM   #1
srosqvist
Guest
Member#:
Smile hint for 2.5RS automatic owners
Here's a hint on how to get off the line real quick if you own a 2.5RS automatic.
Keep your left foot on the brake pedal real firm and right before the light turns green, rev your rpm's up between 2 to 3 thousand. As the light turns green let go of the brake pedal and floor it. You'll be gone. I've devoured many oppositions off the line this way. Note though that I have no idea if this is bad for the tranny. Oh, and be safe!!!!!
Old 02-02-2001, 02:02 PM   #2
tomrichardson
Member#: 2672
1973 Porsche 914
Porsche Red
Post
Not sure if it's bad for the transmission, but I would imagine that it would be bad for the brakes. Cause basically you're transferring power to the wheels with the brakes on. So, it doesn't seem logical that it would be that bad for the transmission.
You didn't mention if you were in Neutral when revving, so I assume you were either in 1st (L?) or Drive.
Sounds pretty cool tho.
Later,
Tom
tomrichardson is offline   Reply With Quote
Old 02-02-2001, 02:08 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Well let's see... it heats up the trans fluid a bit, but other then that I don't see much damage. It'll put some stress on the brakes, but it won't cause damage because they are purely mechanical and need to be moving to cause wear. BTW, people do this in turbo cars to spool up the turbo before launch... much better launch with an auto then a stick just because of that, I would think.
Old 02-02-2001, 02:11 PM   #4
micah
Member#: 3154
Post
This is known as "brake torquing" and is a staple of automatic drag racing technique.
Note that it's not really bad on the brakes at all because the wheels aren't turning while the brakes are applied.
It's not really too bad on the transmission either other than warming it up a little. All of the slip is absorbed by the torque convertor. There is a certain RPM that you will achieve even with the throttle floored called the "stall speed". You hear muscle car guys talking about swapping in torque convertors with higher stall speeds to achieve better 1/4 mile times.
Now, one thing that _would_ be bad is to floor it with the car in neutral and then drop it into drive. DO NOT i repeat DO NOT do this to your next rental car. I certainly would never do such a thing.
cheers
mbs
micah is offline   Reply With Quote
Old 02-02-2001, 03:11 PM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Wink
hehehe
i did that all the time in my GT... go baby go!!!
surprised a lotta people that way...
and no.. it did not hurt my brakes or my tranny... + i had a tranny cooler anyway.
j. www.subiegal.com
Old 02-02-2001, 03:56 PM   #6
KITTbri
Member#: 2748
1992 WHT SE-Rw/stuff
2.5RS & '01 Mazda MP3
Post
i have been powerbraking for a long time with mine. just don't hold it too long... bad mojo...
at my last oil change they wanted to swap my tranny fluid 'cause it was too dark he he...
do need to be careful tho
KITTbri is offline   Reply With Quote
Old 02-02-2001, 04:06 PM   #7
Fred Fredburger
Member#: 2539
Post
Subie Gal> i did that all the time in my GT... go baby go!!!
I assume you're talking about brake torqueing and not dropping it from N to D with the engine revved, right?
Geoff
Fred Fredburger is offline   Reply With Quote
Old 02-02-2001, 04:59 PM   #8
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Last night I had my turbo in my car I went to a deserted strip by the airport to do a couple of wot runs so I'll have something to remember it by!
Anyway, just remember to keep your foot planted on the brake all the way down, cause a turbo packs a lot more torque!! First time I did it I didn't have my foot all the way down and the car started creeping...but of course I just gunned it! Boy was that a good feeling!
Keiho is offline   Reply With Quote
Performance Products for 04-05 2.5RS Automatic GREGS2point5 Normally Aspirated Powertrain 15 01-12-2006 03:23 PM
2002 2.5RS Automatic 0-60 and 1/4 mile? grue Normally Aspirated Powertrain 6 04-24-2002 10:45 PM
WRX automatic vrs 2.5rs automatic DoctorNick Transmission (AT/MT) & Driveline 7 09-05-2001 03:50 AM
Need help from fellow 2.5RS automatics! ImprezedRS Normally Aspirated Powertrain 10 06-26-2001 07:57 PM
('93-'01) 2001 2.5RS automatic VS. 6 cylinder Mustang coloradobound Impreza Forum 1 06-15-2001 09:27 AM
