Old 02-11-2001, 03:51 PM   #1
CO Sube
Member#: 4138
Question Benefits from a flywheel?
I am considering a 12lbs. flywheel for my RS. Does the flywheel actually make the car faster or is it just for improved feel?
Casey
CO Sube is offline   Reply With Quote
Old 02-11-2001, 04:18 PM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
I makes it faster - allows the engine to rev faster, and carries the car along faster as a result.
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 02-11-2001, 04:46 PM   #3
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Question
Does it make the car slow down quicker after you let off the gas? Would a lighter flywheel be useful on both a 5-spd and an auto?
John2.5RS is offline   Reply With Quote
Old 02-11-2001, 04:59 PM   #4
Die Civic
Member#: 3301
2001 RS
Post
yes which would also cause it to stall easier if you're not concentrating.
Die Civic is offline   Reply With Quote
Old 02-11-2001, 07:55 PM   #5
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
Lightbulb
The theory would be that it will make all your gears alot more powerful than they are now. That is because its easier to get the revs up, especially 4th and 5th. When I get it I will let you guys know.
Zee
Sunrise City Rider is offline   Reply With Quote
Old 02-12-2001, 02:06 AM   #6
Lix
Member#: 1560
Post
I was thinking about getting this mod eventually too, but I live in a hilly area, and I think that the lighter fly wheel might actually hhinder performance.
My thinking: A heavier flywheel stores more kinetic energy (well I guess if it's storing it, then it's potential energy...oh well), so when it's in motion, it's more likely to stay in motion. So if I'm in a flat part of the hill, and I reach an uphill part, then I should have more momentum with the heavier flywheel. Would a lighter flywheel still rev faster in this situation?
I'll probably do more research on this before I find it, but if someone has the answer, please enlighten me. Thanks.
Lix is offline   Reply With Quote
Old 02-12-2001, 04:02 AM   #7
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Post
I was considering the lighter flywheel, but now that I have turbo'd my car I don't think I will get one.
1st and 2nd go by way to fast now, and with a lightweight flywheel the problem would be compounded. If the rev limit was a bit higher the flywheel might be worth it to me with the turbo.
I would be curious to drive a car with a flywheel to actuallly feel the difference.
Aaron
http://www.azscooby.com
AaronB is offline   Reply With Quote
Old 02-12-2001, 05:41 AM   #8
Safir
Member#: 3873
. Paradise is
like Disney with hookers
Post
I was thinking of upgrading (or downgrading, depending how you look at it) to a lighter flywheel simply because it takes about 3x as long as it takes me to complete a shift for the engine speed to get back down. So every time i shift i am waiting for the engine before i can get back on the gas (normal city driving here folks, I am not trying to kill my clutch to shave a couple tenths off my 0-60 )
any thoughts on this theory? anyone else notice it seems to take an awful long time for the engine speed to drop?
Safir is offline   Reply With Quote
Old 02-12-2001, 08:46 AM   #9
motorob
Member#: 2878
06 Evo IX MR
Lightbulb
A lot of factory turbo cars used come with HEAVIER flywheels for just this reason, and to make launch easier, the flywheel stores enery to get the car through the lag period... I don't know if they still do.
motorob is offline   Reply With Quote
Benefits from using the radiator cap from a new model WRX on a 2002? (higher Bar/kPa) djerickd Service & Maintenance 50 11-18-2013 11:24 AM
Benefits from a upgraded fuel pump? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-23-2002 09:43 AM
Tweeters in frond & at the back? Any benefit from it? 25psi Car Audio, Video & Security 4 06-06-2002 04:17 PM
Any Benefit From Leaning Out Mixture At WOT with SAFC? MY99 2.5GT Normally Aspirated Powertrain 4 02-20-2002 02:07 PM
Anyone have proven benefits from JCS TCII?? 96Lconversion Normally Aspirated Powertrain 88 06-09-2001 01:13 PM
