Old 02-10-2001, 11:17 AM   #1
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post Question on 4EAT
My car was previously turbo'd, and during that time I got a tranny oil cooler installed as well. However I haven't switched to synthetic fluids yet, and haven't changed fluids as well. Car is a MY00 with about 24000km. Mods now are underpulley, intake, exhaust, hyper r.
Anyway, when I'm driving it now, sometimes the shift from 3rd to 4th would be "weird". By weird I mean the car would seem to rev in neutral before shifting up. All this takes place in about half a second or so. Granted it does this when the tranny is still cold probably, but it occasionally does it when I've been driving for some time. My question now is how do I go about fixing this problem then? Change the tranny fluid?
Powerwise and everything it is good, doesn't appear to be any slipping, save for that slight "rev in neutral before upshifting" fiasco.
Keiho is offline   Reply With Quote
Old 02-10-2001, 04:51 PM   #2
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Anyone?
Old 02-10-2001, 07:17 PM   #3
inpreza kid
Member#: 3334
Post
i would like to know this too. i also have a MY00 but i have only 5500km on mine and it does the same thing when its under WOT acceleration
inpreza kid is offline   Reply With Quote
Old 02-10-2001, 07:21 PM   #4
MPREZYA
SCIC
Member#: 85
Post
Sounds like the High Clutch. Mine was doing sort-of the opposite which was while doing @70mph going to pass it would go to downshift and "neutral or tach out". I am currently going through a rebuild as when my tranny was torn apart it was determined the valve body, high clutch (was leaking and out of tolerance but in specs according to subaru ), and a few other parts.
If you do a search for a post I made "attn automatic tranny owners 93-98" and it explains alittle more.
Rich
MPREZYA is offline   Reply With Quote
Old 02-10-2001, 10:01 PM   #5
inpreza kid
Member#: 3334
Post
MPREZYA keiho and i have MY00 auto's
Old 02-10-2001, 11:37 PM   #6
MPREZYA
SCIC
Member#: 85
Post
I know that but the issue still pertains to our subaru automatics. The symptoms are still something that points to the high clutch no matter if you had a 1991 SVX. The automatic in our cars has not changed much from then. I suggest holding out on taking it for service till the problem becomes easily repeatable or you start to notice a flashing AT TEMP light as that means an error code readable by a scan tool.
Otherwise you will more than likely pay for teardown for them to try and BS you into saying nothing is wrong and warranty won't cover it.
Old 02-11-2001, 11:59 AM   #7
Joe Hogan
Member#: 699
2002 golf TDI
Post
Speaking with folks that have seen dealer inventory of retired warranty replaced new trannys... and having a MY00 tranny apart ... apparently there are some significant warranty issues with the newer 4EATs.
Any problems should be reported to the dealer immediately to document a possible warranty repair/replacement.
The tranny that I'm building had only 5k miles on it but had bearing damage not seen on transmissions with over 100k on them.
Joe Hogan
Joe Hogan is offline   Reply With Quote
Old 02-11-2001, 04:01 PM   #8
inpreza kid
Member#: 3334
Post
so joe are you saying that i should take my car in to see the dealer as soon as possible? the local dealer i have is a @ss to me. i don't think they will replace my tranny just because it does it throws out of gear the odd time.
Old 02-11-2001, 07:12 PM   #9
Joe Hogan
Member#: 699
2002 golf TDI
Post
My thought is to document the problem with a dealer. If the problem gets worse you will be able to point to a documented history you have established, by going to the dealer and complaining, to get an area rep involved with any warranty claim.
Just a thought ....
Old 02-11-2001, 09:18 PM   #10
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Thanks for the help guys. Will get to my dealer and have them check it out soon.
Question for 4EAT owners 92XJET Transmission (AT/MT) & Driveline 4 10-09-2006 02:10 PM
Question about 4EAT tranny in 96 OBW. eseiler Normally Aspirated Powertrain 1 09-19-2006 12:21 AM
Final Drive question... 1993 4EAT AWD. FederalAuditor Transmission (AT/MT) & Driveline 8 03-03-2005 06:26 PM
Drainand refill on 4EAT on '98 L with EJ22? shortlid Legacy Forum 3 01-21-2005 07:26 PM
question on 4eat can anyone help? snipes Texas Impreza Club Forum -- TXIC 5 02-06-2002 01:37 AM
