Old 06-18-2004, 06:19 PM   #1
DickWRX
Member#: 60590
Default A rubber hose by DP....
Hey
The rubber hose that runs down the DP< what is it for. FOr some freaking reason it came of the little clamp that holds to the firewal and it started to melt. I smelled it in my car and I just janked it out. I ordered a new one, so I am waiting for it to come in.
am I ok Without it for now?
Thanks
Rich
DickWRX is offline   Reply With Quote
Old 06-18-2004, 06:40 PM   #2
SlideWRX
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
ac drain hose - might puddle up in the car
Tom
SlideWRX is offline   Reply With Quote
Old 06-18-2004, 06:41 PM   #3
DickWRX
Member#: 60590
where in the car
Where is the AC located?
Old 06-18-2004, 07:08 PM   #4
WRXRgr
Member#: 54942
2004 WRX
Originally posted by DickWRX
where in the car
The condenser is roughly between your firewall and glovebox...about where that rubber hose disappears into firewall
If it's not melted all the way back to the firewall, you can probably live with it...all it's doing is letting the condensate from A/C operation drip free, instead of running down your firewall.
WRXRgr is offline   Reply With Quote
Old 06-18-2004, 07:34 PM   #5
BeeGee
Member#: 27724
1970 F100
Black/White
If you have an aftermarket downpipe you can move the clamp that holds the hose one hole further away from the downpipe which will keep the hose even further away. It might crinkle it a little, but no big deal.
BeeGee is offline   Reply With Quote
Old 06-18-2004, 08:53 PM   #6
kunfuzion
Member#: 1094
'85 Levin Hatch
color of rust
its not the condenser, its the evaporator. the condenser is in front of the radiator. but yeah its just to vent moisture.
kunfuzion is offline   Reply With Quote
Old 06-18-2004, 09:36 PM   #7
WRXRgr
Member#: 54942
2004 WRX
I always do that! Dat HVAC stuph is just so...kunfuzin
Old 06-18-2004, 09:54 PM   #8
kunfuzion
Member#: 1094
'85 Levin Hatch
color of rust
its all good. i only know it cause i work the damn stuff
Old 06-19-2004, 12:02 AM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you cut or removed the hose so it no longer extends past the firewall outside the car, it wouldn't be a good idea to run your AC until you replace it. Otherwise you will have water from the evaporator core leaking into the car and getting the passenger side carpet wet.
Old 06-19-2004, 12:10 AM   #10
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Yep!
Keep that hose.
DrBiggly is offline   Reply With Quote
Old 06-19-2004, 12:15 AM   #11
WRXRgr
Member#: 54942
2004 WRX
Good point!! ...and having been in a work vehicle that was like that, that stuph be stankin' , after a while!
Old 06-19-2004, 11:47 AM   #12
KanosWRX
Member#: 17904
010 STI
I had that thing resting on my dp for a long time, ended up burning a hole in it. Is it just a hose you can take out and then put a new one in, nothing holding it in on the other side of the firewall? I might just cut it right above the dp, couldn't be anyworse then when it rains and gets the dp wet.
KanosWRX is offline   Reply With Quote
Old 06-19-2004, 12:00 PM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It's attached to the bottom of the HVAC box inside the car. You can see and access it if you look under there on the passenger side.
Old 06-19-2004, 12:19 PM   #14
BeeGee
Member#: 27724
1970 F100
Black/White
As mentioned above, you'd be better off just moving the plastic hose bracket one hole over from the one it's in and you won't have any problems with the dp melting the hose.
Old 06-19-2004, 01:19 PM   #15
AlboWRX
Member#: 37719
2003 WRX
Another HVAC man in the house.The only difference i work on houses not cars.
AlboWRX is offline   Reply With Quote
Old 06-19-2004, 02:33 PM   #16
KanosWRX
Member#: 17904
010 STI
So if you pull back the carpet in the cabin you can gain access to it? maybe I will jsut buy a new one and turn it the other way.
Old 06-21-2004, 10:44 AM   #17
SlideWRX
Member#: 3803
07 Mustang GT
I think the hole for the hose sits just above the carpet.
Tom
Old 06-21-2004, 12:28 PM   #18
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Removing the kick plate that covers the ECU will help getting to the hose.
mbiker97 is offline   Reply With Quote
Unwrapped DP Burning a rubber hose... aaron6301 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 04-25-2007 08:54 PM
Rubber hose coming into contact with aftermarket DP? ScoobySnacker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 08-09-2006 07:33 PM
installed DP what to do about rubber hose 2005wrx General Community 4 05-08-2006 06:25 PM
rubber hose on dp?? everkain Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-21-2005 11:17 AM
Rubber Hose By Downpipe? STI 2 NV Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-30-2004 08:18 PM
