Old 02-11-2001, 01:46 PM   #1
Kimbie
Member#: 2921
2000 RS
Arrow Oil Drain Torque Spec?
I have done a search and I can't find a spec on how much torque to put on my oil drain plug. Does any one know?
Kimbie is offline   Reply With Quote
Old 02-11-2001, 02:20 PM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Post
Tight but not too tight.
I've never used a torque wrench to do an oil change... I know, some people swear by them, but I say BAH. Get a new washer and clamp it down. If you're big enough to worry about stripping the threads out, use a 3/8 drive wrench. Do you think that the guys at the quickie lube bother using a torque wrench?
CosmoTheCat is offline   Reply With Quote
Old 02-11-2001, 03:08 PM   #3
Rob K
Member#: 2777
Post
That is one of the many reasons I will never take my car to a quickie lube place.
Rob K is offline   Reply With Quote
Old 02-11-2001, 03:09 PM   #4
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
33 ft lbs +- 3.6
-From the MY00 service manual.
(edit) And yeah, use a new crush washer every time.
[This message has been edited by Revision (edited February 11, 2001).]
Revision is offline   Reply With Quote
Old 02-11-2001, 03:29 PM   #5
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
Post
I am an auto technician and I never use a torque wrench to tighten a drain plug. It is not needed. When you remove the drain plug inspect its threads to see if it should be reused. If the threads are good put a new crush ring or gasket on and tighten with a hand wrench until the crush ring compresses a little. If you have the guage pack on you impreza the drain plug is also the sensor for the oil temp. guage. I would make sure not to damage this item because you will have to replace the sensor.
KONKILR is offline   Reply With Quote
Old 02-11-2001, 06:58 PM   #6
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
<FONT face="Comic Sans MS">Just get a fumotovalve... you will never need to loosen/tighten that damn nut again, or buy another crush washer... http://www.fumotovalve.com/ We need the number F105 for the Subarus (all of them- Legacy, Forester, Impreza) and I recommend the one without the nipple for a drain tube... it hangs too low (at least on the Impreza). The nipple-less one hides up underneath my front skidplate nicely. All of $25 shipped to your door. Thank you to Peaty for sucking me into something else
Brian
AIM: NUrsalia ICQ: 84483950
http://members.nbci.com/_XMCM/northu...reza/index.htm
Is that a chicken up there? Nope, just the way he's holding the grapefruit!
</FONT f>
Old 02-11-2001, 07:02 PM   #7
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Post
It does make oil changes a snap and no need to get new washers every time either,
Pics on the AZScooby.com site for anyone wanting to see what these look like.
Peaty is offline   Reply With Quote
Old 02-11-2001, 07:15 PM   #8
Joe Hogan
Member#: 699
2002 golf TDI
Post
Ditto on the Fumuto Valve greatest thing since oil filters replaced screens...
Joe Hogan is offline   Reply With Quote
2005 WRX Oil Drain plug Torque specs? ragejed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-21-2005 01:16 AM
turbo-oil line torque specs? scoobin' Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-07-2003 12:48 PM
Oil Pump Torque Specs Turbo GC4 Normally Aspirated with bolt-on Forced Induction Powertrain 7 04-20-2003 05:17 PM
Anyone know oil filter torque specs? Gumpy Service & Maintenance 4 01-02-2003 10:09 AM
torque specs? (stock rims & oil drain nut) nav Normally Aspirated Powertrain 7 04-01-2001 07:05 AM
