Old 06-18-2004, 10:06 PM   #1
nqwan
Member#: 2916
02 duburu arr exu
Default Leak from turbo oil line. Need help ASAP
For a couple days now I've been getting some white smoke from the passenger side of the engine bay right around the turbo once the car was warmed up. Well today I noticed more smoke than usual and after poking my head around the turbo area, I found the source.
here's a pic:
The leak is pretty significant. If I start the car a thin spray of oil will shoot out of the fitting towards the fenderwell. Its coming from the fitting on top of the banjo bolt that the metal tubing comes out of (circled in red in the pic).
After inspecting it more closely, it kinda looks like the tubing is cocked a little. Will bending it back be a safe way of possible fixing the leak? Is there anyway I can patch the leak if that wont work? I need to get this fixed ASAP since the car is my daily driver Any help will be GREATLY appreciated!
nqwan is offline   Reply With Quote
Old 06-18-2004, 10:20 PM   #2
nqwan
Member#: 2916
02 duburu arr exu
update: well i thought the tubing fitting was one of those ferrule things that gets crush around the tubing to form a seal. after looking at it even closer with a mirror, i realized its welded/brazed and the leak is from a hairline crack in it...
will jb weld be strong enough to seal it? anybody know of anything else thats good for fixing cracks in metal?
Old 03-29-2008, 12:05 AM   #3
Ken-Ohki
Member#: 11222
2015 Chevy Volt
heh, I just ran into this problem today. darn banjo bolt is spraying oil. turbo has been on the car for 50k miles. tightened it and it still sprays.
going to try brazing it i think
Ken-Ohki is offline   Reply With Quote
Old 03-31-2008, 05:27 PM   #4
Ken-Ohki
Member#: 11222
2015 Chevy Volt
well, neither jb weld or silver solder worked for me. looks like the $70 for a SS braided line is the way to go.
i'm posting in this to make sure the next guy who has this issue gets the info
NEED help ASAP!! oil feed line,, wickedblk02 Newbies & FAQs 6 03-28-2010 03:42 AM
Leaking Oil! I Need Help ASAP steve2k1116 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 04-28-2009 08:38 PM
Turbo oil line leak. Hotrod, you have info on the SS line? Tex-WReX Texas Impreza Club Forum -- TXIC 0 05-16-2005 10:28 PM
Need help ASAP! Found oi leak at bottom of stainless steel oil line on my sr50 odin1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 10-18-2004 12:37 PM
NEED HELP ASAP with oil feed line onyxhunter Tri-State Area Forum 2 09-28-2004 08:06 PM
