Old 06-19-2004, 10:51 AM   #1
gregster_m
Member#: 63740
Default Disassemble the power window master switch?
Anyone know how to take apart the driver's side power window master switch? Mine is faulty - the passenger's side window will roll down but not up - from both switches - and testing with a multi-meter indicates that the problem is in the master switch. All the switch likely needs is a spash of contact cleaner, but I can't get at the switch because of the way it's put together. It looks like it should easily come apart, but it doesn't want to, and I don't want to force it, since I want to avoid having to buy a new one!
Any suggestions.
gregster_m is offline   Reply With Quote
Old 06-19-2004, 11:12 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You can gently pop the switch module out of the trim piece with a small screwdriver, but that may not help you much. To open the module up any further to access the switches would require a lot of desoldering, and unless you have the proper equipment and skills to do this I don't recommend attempting it. The circuit board can easily be damaged beyond repair.
I would not suspect the switch itself anyway, these are very reliable units and I have never heard of one going bad. You should thoroughly check the wiring and connectors first before diving into the switch.
The only connection that requires the main switch to be present for the passenger one to work is the ground, which passes through the main switch.
If you really believe the switch is bad you can take it to a junkyard and try to match it up. It is actually a Nissan part and is probably identical to the ones used in certain Nissans (Maximas, Pathfinders etc.) that should be plentiful in junkyards.
WTB: window master switch CSwrx22 Interior/Dressup/Audio & Security 3 04-22-2010 05:57 PM
WTB 05+ Power window/lock switches, all doors Hando567 Private 'Wanted' Classifieds 1 08-21-2007 01:21 AM
Where is the power window relay or power window circuit breaker iam1ru12 Electrical & Lighting 0 03-15-2005 01:58 AM
almost done changing interior lighting, has anyone done the power window switch? Tobey Electrical & Lighting 24 08-25-2004 04:11 PM
