Old 02-10-2001, 10:03 AM   #1
Tensecgn
Member#: 2102
Post what clutch to purchase
I have a 92 legacy 5 speed 2wd with a turbo and a 2.5l shortblock.What clutches are availible to hold the power this thing will make.
Tony
Tensecgn is offline   Reply With Quote
Old 02-10-2001, 08:48 PM   #2
tluzziracing
Guest
Member#:
Post
my recommendation is use a stock disc and a act or clutchmaster pressure plate.the problem in our cars is the weak pressure plate.i use a clutchmaster PP and a stock disc and im running 8psi.its never slipped and my tranny is still alive.
also the reason our cars get that shudder is the PP,since i changed mine ive never had that problem again,even the dealerships reccomend this.
Old 02-11-2001, 12:19 AM   #3
Tensecgn
Member#: 2102
Post
Old 02-11-2001, 12:50 AM   #4
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Post
Well, I'm going against the ACT-equipped masses and trying ISR's kevlar disk with the stock pressure plate. I'll certainly post results when I get the clutch (and my turbo) installed.
They're at www.autocaresubaru.com
Jon Bogert is offline   Reply With Quote
Old 02-11-2001, 03:39 PM   #5
Aspen
Member#: 145
Banned to
Housework for Summer
Post
If you are using the '92 FWD tranny then your choices might be very limited to a few on hand. Most of those choices will give you a harsher engagement than stock too since most of the clutch sets I've seen for the early model trannys use a 4 and 6 puck design.
ClutchMasters, ACT, ClutchNet all have applications for early model Subaru FWD trannys.
http://aspen.mwic.org/22lm
Aspen is offline   Reply With Quote
what impreza to purchase?? burtonforlife Newbies & FAQs 20 04-24-2005 10:14 PM
What clutch to go with? azimiut Transmission (AT/MT) & Driveline 2 09-21-2004 11:13 PM
What clutch to go with? WrxRacer305whp Transmission (AT/MT) & Driveline 2 09-12-2004 04:28 PM
what clutch to go with?????? RedSun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-24-2004 08:38 PM
what clutch to go with N/A setup? imprezey Transmission (AT/MT) & Driveline 23 02-07-2003 03:03 PM
