Old 02-10-2001, 01:08 AM   #1
Max
Member#: 788
1989 GMC 1500
Post NA Intake Supercharging
Check this out if you're into NA engines.
http://hre.com/shoptalk/staug95.html#SC1
According to this the RS intake manifold is already the proper length for increased Volumetric Efficiency, if you measure to the plenum.
But what if you measure to the air inlet?
That would make a filter that uses the hood scoop for cold air better. Has anyone tried this?
[This message has been edited by Max (edited February 10, 2001).]
Max is offline   Reply With Quote
Old 02-11-2001, 12:58 AM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
Brucelee, burninrubber, and dcrawford and 8Complex have all done something in this vien, different variations - burninrubber actually sealed his airbox to the scoop and found he was pressurizing the crankcase throught the three lines running to his airbox. This is NOT good.
Larry www.ImprezaRS.com
ImprezaRS dot com is offline   Reply With Quote
Old 02-11-2001, 01:00 AM   #3
ImprezaRS dot com
over boosted again
Member#: 1458
Post
Also, I make cold air intakes that retain the stock air plenum, and hundreds of people are happy with them. The air plenum does indeed tune intake pulse harmonics.
Later,
2.5 NA intake manifold and harness. limestoner Engine/Power/Exhaust 1 05-26-2007 10:22 AM
NA Intakes cmiovino Normally Aspirated Powertrain 37 04-09-2007 11:39 PM
NA intake Dreammaster2.5RS Private 'For Sale' Classifieds 8 12-01-2005 09:12 PM
Ti exhausts and NA Intakes GPMotoInc Engine/Power/Exhaust 13 10-01-2004 07:22 PM
Beer + Boredom = true ram air NA intake Daveish Normally Aspirated Powertrain 30 05-05-2002 04:37 PM
