Old 02-06-2001, 02:51 PM   #1
Jonnathan
Member#: 4003
2000 RS-WRX
BRP
Post Pulleys ?
I've heard a bit about gaining so-called "free-power" by changing my underdrive pulleys.
Possibly around 2 or more HP per lb saved from the weight of the pulley ?
But I also heard that a slight diameter decrease sends less power to be used by other driven devices such as the air-con.
So which do I want ? reduced weight or diameter, or both ?
Jonnathan is offline   Reply With Quote
Old 02-06-2001, 04:39 PM   #2
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
An under-drive pulley should only rob power at idle. You should not see any power drain at speed. That's the beauty of an under-drive.
You can get a pulley that under drives even further, but there isn't really any reason too. If you want to go to that extreme, you should just get rid of the accessory pullies altogether.
gavin is offline   Reply With Quote
Old 02-06-2001, 05:02 PM   #3
Jonnathan
Member#: 4003
2000 RS-WRX
BRP
Post
what about weight reducing pulleys, vs. smaller diameter pulleys ?
whats the difference ?
I'm guessing smaller diameter saves power lost to air-con etc, and less weight means less rotational inertia for the engine to overcome.
So where can I buy a reduced weight, reduced diameter pulley ? I guess I'll have to buy new pulley belts too
Old 02-06-2001, 08:16 PM   #4
suby ej25
Member#: 3047
2001 Impreza Rs
Post
you can check teague's auto, cobbtuning, flatline motorsports...basically any suby specializing place will have the unorthodox racing underdrive pulley(both reduced weight and diameter)..some places will sell it with the new belts..should run about $180
[This message has been edited by suby ej25 (edited February 06, 2001).]
suby ej25 is offline   Reply With Quote
Old 02-07-2001, 04:55 AM   #5
suby ej25
Member#: 3047
2001 Impreza Rs
Post
i was just browsing the private classifieds board...if you still want a pulley...someone is selling their's
Old 02-07-2001, 05:56 AM   #6
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
Post
Jonnathan,
Do other mods (swaybar,intake or exhaust) before you buy the unorthodox racing underdrive pulley.
IMHO It is simply is not worth the money.
-some people will disagree with me-
but they are wrong
Good Luck
Rich L is offline   Reply With Quote
Old 02-07-2001, 08:04 AM   #7
Jonnathan
Member#: 4003
2000 RS-WRX
BRP
Post
Thanks Rich L, I allready have P1 suspension, 20mm sway bar and ScoobySport Exhaust mods : )
I'm was gonna do the intake and underdrive pulley at the same time. Why don't you think its worth it ?
The shops claim up to 2.7 hp gain, per lb lost from the pulley. ? is this not so ?
Old 02-07-2001, 09:20 AM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Post
Jonathon,
The Unorthadox pulleys are both lighter and smaller. The weight reduction is 2 lbs. I believe. I got mine for $125 from SPO with belts. I did notice the change in throttle response pretty immediately, but I don't have an intake, just a K&N panel filter. My point? Someone with a true intake is less likely to be able to feel the difference and not think it is worthwhile because they have already gained 10-15% power from their intake.
As for the impact on the accesories? Zero. Well, the power steering belt squeks when cold, but goes away after 5 minutes. But otherwise, nothing noticeable.
Old 02-07-2001, 02:10 PM   #9
Rich L
Member#: 961
Post
Jonnathan,
I dont think it is worth it because the performance gain is not noticable. I think people "perceive" an improvement, but in all honesty, I think this perception is due to actually knowing the mod was done.
I would recommend getting a test drive in similair cars with and without the pulley.
My butt dyno is not that perceptive to notice the 2-6hp claims, but I noticed better performace gains through an ECU reset. I really cant recommend it to anyone.
Not to mention there is dimming as a side effect. (I havent had any belts slipping/squeeking though). The dimming becomes even more apparent with added accessories (I have airfuel/boost/oil temp gauges).
Use you money to enhance other mods. With the extra $200... get a better intake, or put it toward a lighter flywheel, headers, or tires. (or a digital camera for internet pics)
Anyway you spend it, the $200 better off being put to good use someplace else.
Old 02-07-2001, 02:37 PM   #10
Jonnathan
Member#: 4003
2000 RS-WRX
BRP
Post
Is doing an ECU reset risky in any way then ?
Is an ECU reset done by disconnecting the battery for half an hour or so ? , then restart car, and let it adle and warm up ???
Does that make your Mileometer readings dissapear ?
Does it make any difference what gas you have in your tank when you do an ECU reset ?
Old 02-07-2001, 02:44 PM   #11
Jonnathan
Member#: 4003
2000 RS-WRX
BRP
Post
Yes a digital cam would be nice : )
I have a few pics on my website ripped off from other places, but need to get some of my own done : )
there is a link to my crappy website on my profile : )
Old 02-07-2001, 04:49 PM   #12
Matt Monson
Member#: 832
99 2.5RS, '85 911
Post
Jonathon,
All your ECU questions are covered in the new FAQs section in detail.
As far as the pulley question, in his last post, Rich mentions his "boost" gauge. This leads me to believe "turbo", and if anyone is running a turbo, I don't think the pulley is really worth much either. It is with milder NA mods it will have an impact. I would not have bought one if i didn't have a gift certificate about to expire and a Cobb intake already ordered. Otherwise my money would have gone towards an intake.
Old 02-07-2001, 05:41 PM   #13
Rich L
Member#: 961
Post
Jonnathan,
An ECU reset is recommended at each oil change. Try to put in an octane booster at that time, you will notice a differance. That will give you 5 good hp! (or preserve 5 hp)
Matt,
yes a turbo is a worth wild mod!
it is worth every penny and guys in z-28s learn to respect you! Anyway it is good that someone cares enough to give you a gift certificate for any mod!
Make sure you guys go to the KC event, we can tech talk and talk mods. Hopefully see some good Scooby action.
Old 02-07-2001, 05:58 PM   #14
ice
Member#: 3218
Post
So for those of us that are still N/A, that have already done and intake and exhaust, this is a noticable mod? I've been considering a pulley set, and I would really like to know if it is worth it or not.
ice is offline   Reply With Quote
Old 02-10-2001, 09:11 AM   #15
JC SPORTS
Guest
Member#:
Post
We have a lightweight pulley that is the same size as stock for $137.95. We also carry the UD pulleys for the same price (belts are additional)
Old 02-10-2001, 03:13 PM   #16
adamsrs
Member#: 3768
Post
I just ordered the Unorthodox racing pulleys form Cobb Tuning. He carries only the best stuff!
adamsrs www.unnatural.org
adamsrs is offline   Reply With Quote
Old 02-11-2001, 12:19 AM   #17
Jonnathan
Member#: 4003
2000 RS-WRX
BRP
Post
KC event ?? whats that ? where and when ?
Old 02-11-2001, 12:37 AM   #18
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
I just had the lightweight N1 pulley installed at JCS today - it is about 3lb lighter than stock, and uses the stock belts.
Either Grassroots Motorsports or SCC magazine in the last issue stated that 85% of the gains from a pulley were from weight loss, and the UD pulley with smaller belts is only about 1 lb lighter than this one. They said it was a 2.7hp gain per 1 lb lost. I could tell an immediate difference in free reving the motor and spooling of the turbo. Most notable was the hwy acceleration seems stronger in 3rd and 4th gear. I am very happy with it, although it was not as dramtic as going to a 12lb flywheel. And, in the summer I will still have full AC power.
Larry www.ImprezaRS.com
ImprezaRS dot com is offline   Reply With Quote
FS : JDM 660cc Injectors-GFB Lightweight Pulleys-AEM Wideband-Various Turbo Gauges-MORE! Audioexcels Engine/Power/Exhaust 37 11-02-2010 02:34 PM
pulleys, pulleys and more pulleys msingell Transmission (AT/MT) & Driveline 5 12-22-2007 11:27 PM
Which pulley, N1 three pulley or Cobb Pulley NNeves Normally Aspirated Powertrain 24 04-13-2002 02:38 AM
Part #'s for stock pulley belts...removing UR pulley SFsube Technical Forum Archive 4 08-26-2000 09:46 PM
Pulley sizes for all models and the UD pulley MPREZYA Technical Forum Archive 0 08-14-2000 12:06 AM
