Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 06-19-2004, 10:34 PM   #1
Vendor Sales Rating: (62)
Member#: 67
1999 Outlasting
the competition.
Default Yet Another First from Kartboy!
tom@kartboy is offline
Old 06-22-2004, 03:52 PM   #2
Silver-Bolt
Member#: 40189
2004 STi
Silver/Silver
How does this compare with the factory short shifter. Obviously a much more reasonable price.
Silver-Bolt is offline
Old 06-22-2004, 06:03 PM   #3
Member#: 67
1999 Outlasting
the competition.
from the site
The latest in a series of firsts. The kartboy replacement lever for the Subaru WRX STi 6 Speed is the first non-Subaru version available. With a height reduction of 1" and a redesigned mechanical advantage, a throw reduction of 40% is achieved. CNC machined and Tig welded in the USA. Matched with a set of kartboy shifter bushings (available separately), a major improvement in the shifting is immediately felt, while retaining the factory reverse lock-out.
peaty should have all the install details soon
__________________
Tom Deadrick
American Made Shift!
Old 06-23-2004, 09:27 AM   #4
SkirtBoy
Member Sales Rating: (1)
Member#: 11056
2012 MB C250 CPO
Black on Tan
Tom
Just waiting for the STi combo that allows me to have one of your balls in my hand...
SkirtBoy is offline
Old 06-23-2004, 02:27 PM   #5
Member#: 67
1999 Outlasting
the competition.
Originally posted by SkirtBoy
Tom
i'll see if i can modify one of the mazda ones to work.
shoot me a email monday
Tom
__________________
Tom Deadrick
Old 06-23-2004, 03:13 PM   #6
Silver-Bolt
Member#: 40189
2004 STi
Silver/Silver
One more twist to throw at you. Will this work with the factory STi short shifter? Is there an advantage to combining them or better to add this to the stock setup?
Old 06-23-2004, 03:26 PM   #7
Member#: 67
1999 Outlasting
the competition.
are you referring to the aftermarket STi one for the 6spd? were a bit shorter than that one. should install just the same as the other 6spd one.
tom
__________________
Tom Deadrick
Old 06-23-2004, 04:37 PM   #8
gdog
Member#: 6189
Red No More
Will there be any generalized instructions available before Peaty's write-up? I was planning to install this weekend and would appreciate any pointers.
gdog is offline
Old 06-23-2004, 06:47 PM   #9
Silver-Bolt
Member#: 40189
2004 STi
Silver/Silver
I have the aftermarket (STi/SPT) 6sp short shifter. Would this enhance that more or would it be better to install yours on the stock 6sp assembly.
IE: If the shifter I have now which is a complete assembly (rods/linkage, etc) reduced the throw by 20% would your further reduce it by 40%? I realize that yours is 1.0" shorter in height as well.
If it's no benefit I will sell the current setup and install yours on the stock shifter assembly.
Old 06-23-2004, 07:41 PM   #10
Member#: 67
1999 Outlasting
the competition.
Our shifter would be 40% less than what comes stock on the 6spd setup.
personally i'd sell the other setup and recoup a lot of money
Tom
i'll try and post some quickie install tips.
the only special tools you will need are a set of snapring pliers and a center punch for the roll pin on the reverse lockout.
__________________
Tom Deadrick
Old 06-23-2004, 10:30 PM   #11
Silver-Bolt
Member#: 40189
2004 STi
Silver/Silver
That's what I thought. I will be ordering asap. Thank you.
Old 06-24-2004, 08:44 PM   #12
Fmdeadrick
Member#: 200
1999 Impreza 2.5RS
The linkage, as well as bushings on the STi short throw system from Subaru are the same, only black instead of Gold. The lever itself is the only change. No benefit to using the other components vs the stock ones.
There are a coupld of ways to install the setup. The easy/hard way and the hard/easy way. That is, there is no really easy way. The way Tom and I have installed them, as a team, not individually, is to remove the whole assembly as it attaches to the trans and body, and swap the lever out. The hardest part of installing our lever is lining up the roll pin that goes through the release ring, the slot in the lever, and hole in the cable end. It is easier to do on a bench than in the car.
You could also try to simply remove the lever from the base by removing the c-clip and the linkage, and having someone under the car push/pull the cable to lne it up.
We make no claims that this is an easy install. Give yourself plenty of time and at least one other person to help. This is a good Saturday morning, don't have to go to work in an hour project. Hopefully, we will have install instructions up soon. We have been bombarded with request to start selling these, so we couldnt wait any longer.
If anyone wants to upload some additional install pages, we can work out a good deal for you. Please contact us first, though.
Thanks
Mark
Fmdeadrick is offline
Old 06-25-2004, 03:52 PM   #13
Silver-Bolt
Member#: 40189
2004 STi
Silver/Silver
Having already done the STi short shifter I can attest to the fact that it is not that difficult to install/swap. Can be done very easily on ramps or jack stands. Big time and knuckle savers are to loosen the tranny mount and if you have the ability to drop the center section of your exhaust it's a piece of cake. I did mine when I installed a new TBE so I had the exhaust already off. Plenty of room to work. I easily accomplished it working alone. If you have an extra body it will save you time from crawling out from under the car to the inside and back again.
PS: Just placed my order. I will post feedback how it compares to stock and also the factory short shifter.
Old 06-25-2004, 11:23 PM   #14
Tobey
Member Sales Rating: (3)
Member#: 21400
2015 WRX Limited
ISM
just did my install, there are some quick tips here:
http://forums.nasioc.com/forums/show...hreadid=580470
Tobey is offline
Old 07-10-2004, 09:26 PM   #15
Member#: 67
1999 Outlasting
the competition.
Bump
still a few sets left from the first batch, But they are going FAST!
Tom
__________________
Tom Deadrick
Old 07-22-2004, 11:50 PM   #16
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Tom, send one my way for review!
Leo
Leonardo is offline
Closed Thread
YAQFCC: Yet another question from Capt Crunch Capt Crunch Mid Atlantic Impreza Club -- MAIC 3 05-30-2007 03:48 PM
yet another clip from a japanese gameshow uzer_errors Off-Topic 6 01-27-2007 07:48 PM
Yet Again! Another First From Kartboy! 05 Legacy [email protected] Drivetrain 1 10-23-2004 11:37 PM
Another Subaru First from Kartboy [email protected] Drivetrain 32 03-21-2004 04:01 PM
Yet another noob from STL...various quick questions.. ent2b Newbies & FAQs 3 05-15-2003 11:46 AM
