Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 02-01-2001, 11:24 AM   #1
adamsrs
Member#: 3768
Post Apex'i S-AFC ?
I have had a S-Afc in my car. I have 5Zigen Fireball 2.25" catback, and cobb tuning cold air intake. Can you guys give me an idea of what I should set my settings at.
Thanks
ADAMSRS
adamsrs is offline   Reply With Quote
Old 02-01-2001, 11:28 AM   #2
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
It varies from car to car. Get an EGT gauge to tune with! You shouldn't be blindly using someone else's recommended settings... you won't ever know if you're running excessively rich or lean.
RidinLow is offline   Reply With Quote
Old 02-01-2001, 12:06 PM   #3
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Post
I agree! That's why I ordered an Air Fuel Meter today! I decided to get it and install before I put my S-AFC in! I though maybe this would also give me some idea of where the car was running rich and where it was running lean, before I go to correct it with the S-AFC. Just a thought!
pleiades is offline   Reply With Quote
Old 02-01-2001, 04:05 PM   #4
Wannabeturbo
Member#: 2328
Talking
I just put mine in. I have JC sports intake, 2.5 N1 cat-back exhaust. and the pre-turbo guages (Air/fuel, Engine temp.,Exhuast temp.) I will tell you that the only way to do it is set every value to zero find where you car is running rich/lean if it is a '00 like mine it should run rich. I cured mine pretty much. Did you get any settings from anyone? You set up anything yet or is it unplugged? If you want settings right now call Rallispec and ask them if they could help you out? They are great people and I trust them and I haven't even met them before. Ok I will go off memory what I know for now since I am at work and don't have the sheet in front of me.
First go to settings to pick cylinders and set it to 4cyl.
Go to the arrow beside it and set it to the upward position on the screen.
Go the throttle settings and set the low to 10% and high to 65%
Set the Ne points starting & 2500rpm and increase 500rpm untill you can't set them any more. I think there are eight and you should end at 6500rpm.
Set the sensor type to pressure
Now the fun and headaches start. You have to watch what you do and see how you car runs because none of the settings are the same. You just have to play with all of the Low and high throttle points to see what works best. I would give you mine but I don't want you to run to lean or rich because no ones engine can be set the exact same. You have to set the Low so that the car stays idling good and not rough. Set the High's at %'s where you know it is running to rich or lean.
Then from there on out be watching and feeling how the car runs and reacts. It is best to have a friend ride along and mess with the S-AFC while you drive. Be careful when tuning by the seat of your pants and if you have and EGT or Air/fuel it is best. The Air/fuel may not be the best because it doesn't give a quick and precise measurement right away since the gases have to travel before reaching the O2 sensor.
If you have any problems or questions e-mail me at MWEBER@NEBOILER.COM and I can try to help you out.
I will get back to you on the settings to make sure I didn't miss anything! Hope this helped you out sorry it was a novel!
Later,
-Matt
Wannabeturbo is offline   Reply With Quote
Old 02-01-2001, 05:40 PM   #5
cj917
Member#: 627
MY96 outback wagon
Post
go read Wac's SAFC Tech Notes in the links section (it'll answer most of your questions if not all)
that said, the general rule for MY00 is to reduce fuel below 3500-4000rpm, and add fuel above that... but like what RidinLow was saying, get an EGT gauge
A/F ratio gauge works too, but remember that the relationship between the air/fuel ratio and the output voltage is NOT linear
cj917 is offline   Reply With Quote
Old 02-01-2001, 06:29 PM   #6
inzomniak
Member#: 953
Post
You know what you should do... the next time the Washington guys come up to Vancouver for a meet, join them...
Bring your car to Tecknik Moterwerks (Minnam Racing) to dyno tune it... it's going to cost some money... but I'd trust a professional than myself!
inzomniak is offline   Reply With Quote
HKS Super AFR VS Apex'i Super AFC whiterabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-11-2002 09:02 PM
Apex'i S-AFC on Stock WRX TicalWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-07-2002 11:50 PM
Apex'i S-AFC for Sell inzomniak Vancouver Impreza Club Forum -- VIC 2 02-23-2001 02:23 PM
Apex'i S-AFC vs. Field SFC inzomniak Vancouver Impreza Club Forum -- VIC 5 12-12-2000 12:37 AM
