Old 06-20-2004, 10:25 AM   #1
superg
Member#: 3385
Default Speedo quit
Superg
superg is offline   Reply With Quote
Old 06-20-2004, 10:28 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The sensor is screwed into the outside of the trans case and can be replaced in the car.
It's probably a bad sensor or bad wiring/connection, I'd think if the drive gear was incorrect the speedo wouldn't have worked from the beginning.
Old 06-20-2004, 10:39 AM   #3
superg
Member#: 3385
Default Thanks
Thanks, Mulder. Makes sense to try the speed sensor first since it is accessible.
Superg
Old 06-20-2004, 10:44 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
First, try just unplugging the connector and reseating it. You might get lucky and just have a poor connection there, never know.
Old 06-20-2004, 03:49 PM   #5
superg
Member#: 3385
Default Thanks
Another good idea, Mulder. Especially considering the symptoms this morning: the speedo works above 20 mph and it is accurate above that speed. I am relieved, as it seems more likely it is a sensor/electrical problem than a gear problem.
Superg
Bad MAF sensor or IAC valve? 1507 CEL Hyelude Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-15-2015 02:04 PM
CEL: P0133 O2 Sensor Slow Response (Bank 1 Sensor 1) BLK REX Normally Aspirated Powertrain 18 05-30-2007 03:56 PM
Possible bad o2 sensor? or something else? drkwtsn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-25-2006 03:05 PM
Bad ABS sensor - OR - Hmmm, maybe that wheel bearing is bad after all! Patrick Olsen Brakes, Steering & Suspension 2 08-23-2005 01:20 PM
Bad Mil Eliminator or Bad O2 Sensor? jalow72 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-06-2005 07:49 AM
