Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 06-20-2004, 02:32 PM   #1
jdchmiel
Member#: 926
Default id this turbo for me.. i was told t3/t4 hybrid
I was told it was a t3/t4 hybrid, and it was the bigger of two choices from ludespeed, but it was a to4b compressor, not teh more common to4e wheels. I cant figure out *** it is. It has a t3 turbine with .63 a/r housing, which is as expected, but th ecompressor seems liek it is s alot smaller than it should be. you can see a .50 stamped inside the outlet. The rest of the compressor housing has basically nothing written on it, other than airresearch M10. I used teh standard soda can for size reference, as you can see the inlet fits the can, but it tapers down to quite a bit smaller inside.
jdchmiel is offline   Reply With Quote
Old 06-20-2004, 02:42 PM   #2
Unsung Boxer
Member#: 37196
no clue, but its big. Kastle or 8 will probably know
-Jake
Unsung Boxer is offline   Reply With Quote
Old 06-20-2004, 02:44 PM   #3
jdchmiel
Member#: 926
i hesitate to think it is too big, because before I blew the shortblock ( the only reason it is off the car now) I could spool that thing very easily. I could rev it a few times, and launch at 3500 rpm, and be basicaly under boost from launch..
I was only running 6 psi tho... ??
Old 06-20-2004, 04:06 PM   #4
kaos200
Member#: 2692
edit cus I cant read
kaos200 is offline   Reply With Quote
Old 06-20-2004, 04:10 PM   #5
8Complex
Member#: 922
04 FXT
Red
IIRC, Ludespeed offered a t04s at some point, which I think may have been the largest turbo they put in the kits.
No idea what that is other then the guess. *shrug*
Old 06-20-2004, 04:43 PM   #6
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
That would be my guess as well.... There are no notable markings in the pics, so it would be pretty difficult to ID...
kastle is offline   Reply With Quote
Old 06-20-2004, 09:16 PM   #7
jdchmiel
Member#: 926
right, there are NO markings on the compressor side at all. IT is very strange. I measures teh overall inlet at about 2 3/4 inches, and then it has that taper to the compressor, which is about 1 7/8" or 1.875ish inches. that is a fair bit smaller than any of the t4 compressor wheels i have found the specs for so far. it is t3 size range..
Old 06-20-2004, 11:52 PM   #8
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
mmmm, livewire, even turbos love it.
subiekid is offline   Reply With Quote
Old 06-21-2004, 01:26 PM   #9
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Looks like a T3 to me. But at anything less than 14psi, I'd rather have that than a larger T04E/B.
wcbjr is offline   Reply With Quote
Old 06-21-2004, 01:59 PM   #10
jdchmiel
Member#: 926
well from teh response of ludespeed, who didnt know much other than:
Jared,
that compressor is a TA34 and the turbine wheel is a standard TB03.
I don't know if you are going to find compressor maps for that specific
compressor, but that is the model number.
Tom
I was able with google to determin it is a tdo4e 40 trim turbo
flows 37 lb/min, about the same size as a mitsu 16g.
Please id this wagon for me patrickscycleshop General Community 30 01-07-2009 06:12 AM
garret t3/t4 hybrid stage 3 turbo for sale/Trade! ki11switch NWIC Private Classifieds 10 01-03-2009 03:33 PM
Can you id this car for me? KB21 Member's Car Gallery 12 10-20-2008 03:06 AM
garret t3/t4 hybrid stage 3 turbo for sale/Trade! ki11switch Engine/Power/Exhaust 10 07-07-2008 04:41 PM
ID this car for me PYP Off-Topic 25 04-21-2004 08:03 PM
