Old 06-20-2004, 04:39 PM   #1
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Default J&S works after ecu reset
I touched on this in my other thread, but I dont know if I should be worried about this...
http://forums.nasioc.com/forums/show...hreadid=581203
the J&S is alot more active now after reseting the ecu, even the a/f guage part..
more so it retards timing now on heavy rev matching/double clutching....like on the highway at 75mph from 5th to 4th or 4th to 3rd at lower speeds
it only retards it about 5 degrees, (stays way left) when I rev in neutral...(high rpms) between the down shift, if im going 75 and I put it in neutral and rev, nothing.
only inbtween down shifts when I revmatch at high rpms.
It never retards on acceleration/load.
shoudl i be worried?
Jay
Old 06-20-2004, 04:59 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
sounds like its picking up tranny noise or something
Old 06-20-2004, 05:58 PM   #3
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
Definately drop the sensitivity.
no-coast-punk is offline   Reply With Quote
Old 06-20-2004, 06:10 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
problem is I cant turn the adjuster, looks like something is broken off in it...im guessing it came with a blue plast thing to adjust it, wich now seems to be broken off in it...
ill try and get it out....
Jay
Old 06-20-2004, 10:11 PM   #5
Kotir
Member#: 17300
1993 Widebody Wagon
748whp e98
Where'd you mount the knock sensor at?
Kotir is offline   Reply With Quote
Old 06-21-2004, 12:00 AM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
beats me , I bought the car with everything it has.
This is the first time Ive seen the retard lights do anything since I have owned it.
Jay
Keyless entry- reset after ECU reset? sir_aspen_white Electrical & Lighting 1 04-22-2003 08:24 PM
cammed cars--- slower after ECU reset? ColinL Normally Aspirated Powertrain 18 04-11-2001 12:06 AM
Sick of alarm making you deaf after ECU reset? AccidenT Normally Aspirated Powertrain 9 03-26-2001 12:23 AM
Problems after ECU reset Gorio Normally Aspirated Powertrain 10 12-05-2000 06:49 PM
Idle problem after ECU reset Spectre23 Technical Forum Archive 1 05-19-2000 12:42 AM
