Old 01-31-2001, 08:12 PM   #1
98mpreziveRS
Member#: 972
Post Conversion factors dealing with boost
Yes i have searched all the forums..and this being power train..well seems like the BEST forum..not one matches this question perfectly.
*shrug*
here goes..
So..if KG/CM^3 if .7 KG/CM cubed equals 10 psi..then in theory...1.41KG/cm3 is equal to 20psi..right?
SO.. in theory 1 bar equals 14.503773773 psi...which is also equal to around 750.061682703 mmHG..correct? which means that 29.53 inHG = 1 bar..correct?
ALl this is really just checking to see if i am doing my conversions with the right numbers.
Also..for a sti v5 motor what is the stock boost pressure..and what is the most pressure the stock turbo can take..conditions being ideal and tuning be 100%
thanks
98mpreziveRS is offline   Reply With Quote
Old 01-31-2001, 08:16 PM   #2
Aspen
Member#: 145
Banned to
Housework for Summer
Post
Gary,
Already doing the math and you had that gauge in possesion for how long? A couple hours max?
Your conversion seems pretty close to me.
As for the limits of the stock STI turbo, I remember reading in some japanese magazine that it was around 350hp max. I'm not sure if that was on a stock set-up or not(no ported heads, fuel system, ecu, etc.)
Aspen is offline   Reply With Quote
Old 01-31-2001, 09:10 PM   #3
Rob K
Member#: 2777
Post
1bar=29.92inHG=14.7psi
Rob K is offline   Reply With Quote
Old 02-01-2001, 05:01 AM   #4
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
Post
actually, 1 bar = 14.5 psi, not 14.7
-RD
LUME is offline   Reply With Quote
Old 02-01-2001, 07:18 AM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I thought that 1 bar = atmosphere pressure at sea level, which was supposed to be 14.7psi. I'll look it up at work...
Old 02-01-2001, 08:50 AM   #6
edekker
Member#: 143
1999 Impreza 2.5RS
Supercharged - and STOLEN
Post
There's a misconception that the unit 'Bar' had been derived from (or interpreted to mean) 1 atmosphere of pressure. It's more of a coincidence that 1 Bar = 1 atmosphere (slightly less that 1 atm actually).
The unit 'Bar' is actually based on the MKS (Meter-Kilogram-Second) system of metric measurements. The root units from which 'Bar' is derived, is the gram and centimeter.
Since the unit 'gram' was chosen to represent the mass of a cc of water (under a set of strict conditions), there is no absolute mechanism which characterizes (defines) the relationship of 'Bar' to atmospheric pressure.
Ed.
edekker is offline   Reply With Quote
Old 02-01-2001, 01:38 PM   #7
Bob O
Member#: 1502
2000 2.5RS & SV1kS
BRP
Post
98 I sent a conversion program to your email
bob
Bob O is offline   Reply With Quote
Old 02-01-2001, 01:40 PM   #8
98mpreziveRS
Member#: 972
Post
thank ya..seems MUCH easier than doing it the good ol bust out the paper and remember as close as you can get it.
(finally..all them math and science classes have payed off )
Old 02-02-2001, 12:45 AM   #9
98mpreziveRS
Member#: 972
Post
so umm...were my original conversions right?
lol..i did the math using all sorts of calculations and fulled up 2 full pages of paper with numbers everywhere... (i couldn't find a freaking calculator...and don't really trust the computer )
so 14.503773773 psi does indeed equal 1 bar..right?
this is how i based my equations when i did some further factoring and such.
a couple questions dealing with boost gauge light / power BlackoutWRX Electrical & Lighting 1 01-10-2006 10:00 AM
What's the deal with boost controllers? Idrivetripledigits Mid Atlantic Impreza Club -- MAIC 5 06-12-2005 08:10 AM
WRX ECU ignition map conversion factors Kha0S Engine Management & Tuning 0 01-13-2004 11:35 AM
What is the conversion factor to go from Wheel HP to Crank HP? makofoto Proven Power Bragging 11 06-11-2003 03:19 AM
Bar to PSI conversion factor? makofoto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 05-09-2003 01:14 PM
