Old 11-17-2000, 10:06 PM   #1
shukes24
Member#: 1052
you fought
the good fight?
Question to those in cold weather climates (clutch problem)...
To those in cold climates...it recently got a bit chilly here in Chicago and I am having problems putting the car into 1st and 2nd gear, not so much when the car is at a dead stop, but when i try going from a rolling position. Is this normal? I have a my2001 and I've had it for 2 months now (my first manual car). I know people have had problems with syncros, but frankly I have no clue about that subject, since I've only know to drive a manual for 2 months now. Any advice is appreciated.
Thanks,
Nirmit
shukes24 is offline   Reply With Quote
Old 11-17-2000, 10:18 PM   #2
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
Might consider getting a shifter bushing. 1st is sorta sticky on mine too, but the bushing helped alot. Less squirm when putting it into gear. Runs about $30 and takes 10min to put on.
-B
Midwayman is offline   Reply With Quote
Old 11-17-2000, 10:41 PM   #3
couldnthinkaone
Member#: 2944
2000 2.5RS
Steel Blue Mica
Post
i think the problem lies in how the clutch is adjusted. before i adjusted mine i had to push the clutch ALL the way to the floor just to get a clean shift, and i couldn't even think about downshifting into 1st above 4-5 mph. now i have no problem shifting up or down. here is a link to the clutch adjustment page
http://www.egr.unlv.edu/~simon/2.5RS/FAQ/clutch.html
couldnthinkaone is offline   Reply With Quote
Old 11-18-2000, 05:56 AM   #4
Nat
Member#: 759
2004 WRX
2000 SV650
Post
I wouldn't worry about the shifting.....my 99 has done that all along and continues to do it. Of course I am assuming that it goes away pretty quickly after the tranny warms up, right? I like to let my car warm up before I drive it (bascially until I see the temp needle move, I like to let it rise to horizontal position), and this tends to lessen this problem. I want to swtich to a synthetic tranny fluid since the Redline in my '66 Pontiac's gearbox made such a difference.....but after doing some searching here on the board I haven't decided which kind to get. Synthetic fluid would thicken less than regular fluid, so that would halp a bit when it got cold.
Nat is offline   Reply With Quote
Old 11-18-2000, 06:02 AM   #5
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
I wouldn't worry about that either. My MY00 did that for the first couple thousand miles, but it seems to have all but disappeared now.
RidinLow is offline   Reply With Quote
Old 11-18-2000, 06:13 AM   #6
chillN 2.5RS
Member#: 1555
2K RS
BRP
Post
bra we all have that prob i think. its covered under warrenty here. gotta bitch and bitch to get it done!
chillN 2.5RS is offline   Reply With Quote
Stuck clutch pedal in cold weather? ASpec818 Transmission (AT/MT) & Driveline 4 12-26-2007 08:30 PM
Subaru's Harder to start in cold Weather? vincent-h Newbies & FAQs 22 12-09-2005 05:31 PM
('93-'01) Clutch "sticking" in cold weather Seeing StaRS Impreza Forum 11 02-11-2004 12:38 PM
Stiff brake and clutch feel in cold weather? banman Service & Maintenance 3 01-08-2004 03:37 AM
Question regarding what oil to use in cold weather... LisaPhish Legacy Forum 5 11-16-2003 10:35 PM
