Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 06-21-2004, 06:57 PM   #1
awdturbo04
Member#: 39487
2006 sti
obp
Default s-afcII how to tune with auto HELP
well we installed a s-afcII on my friends wrx. its an auto so this might be part of the problem (not sure). well after you get to about 4000 rpm's the car will start bucking and doing random bad things. It almost feels like it is hitting a rev limiter. The mods are full exhaust upipe intake boost controller walbro fuel pump and 650cc injectors all on the stock turbo. It would help if we just had some numbers to go by just to get us rolling in the right direction. thanks.
awdturbo04 is offline   Reply With Quote
Old 06-21-2004, 07:59 PM   #2
parid
Member#: 16336
2002 WRX Wagon
It might help if you give us a little more information about what other tools you might be useing. What kind of a/f data are you getting? Are you useing a wideband? Is it running lean or rich when it starts bucking?
Normally its recomended to do a/f tuning on a dyno with a good wideband o2 sensor. You can do it on the road too, but it takes a bit longer.
Doing some searches could help too. Here is a thread that was somewhat relivent.
http://forums.nasioc.com/forums/show...&highlight=afc
parid is offline   Reply With Quote
Old 06-21-2004, 11:15 PM   #3
Rickyh
Member#: 40453
650 cc injectors are overkill for the stock turbo. you are going to have to make huge corrections in the upper rpm's to hae a decent a/f, I run the same setup with the stock injectors and it runs fine. Do you have a wideband and an egt? With a wideband I have my a/f at 10.8 at 5k moving up to 11.0 at redline.My egt's go no higher than 820. Pulls hard as hell. Put the stock injectors back in and get a wideband if you don't have one. You mentioned an intake. Which one is it?
Rickyh is offline   Reply With Quote
Anyone here know how to tune with OpenECU for LGT? Sleep R Texas Impreza Club Forum -- TXIC 2 07-11-2007 02:03 PM
How to tune with Street Tuner : I need major Noob Help Sausage AccessPort 14 11-25-2006 02:16 PM
any one in the nw know how to tune with accessport? stiraspecc North West Impreza Club Forum -- NWIC 4 08-28-2005 02:18 PM
streetuner + how to tune with intake anthonyrb98 Engine Management & Tuning 2 03-25-2005 03:56 PM
How to Tune A/F ratio with EGT Gauge???? Xscreamer Normally Aspirated Powertrain 2 03-21-2001 09:32 AM
