Old 01-22-2001, 09:56 AM   #1
subarumantoo
Member#: 3257
2000 ImprezaRS
Blue Ridge Pearl
Question JC Sports Torque Chip II
What exactly is a "torque Chip"? Is this the same as the voltage clamp for the MAP cars? Why is it called a torque chip?
[This message has been edited by subarumantoo (edited January 22, 2001).]
subarumantoo is offline   Reply With Quote
Old 01-22-2001, 08:22 PM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
The torque chip II (TCII) is not just the voltage clamp for turbo's cars with MAP sensor, but it does come with and without the clamp.
It increases fuel delivery for modified cars in a variety of ways, but also is supposed to benefit unmodified cars. I don't understand how it works (electrical engineering is a puzzle to me), but have been told what it does. It is very clever.
(1) First it enriches about 6% across the board but can lean out when needed, works with any year model (manual or auto tranny), and allows the ECU to train faster for the best air/fuel and acceleration (about 1 week for best results, but still helps right away).
(2) It has two possible outputs/wires for fooling the ECU into thinking the engine is approx 5% or 10% colder (depends on which wire), so it will enrichen more or less dependent on engine temps.
(3) It follows the car's acceleration (rpm vs time) and adjusts the air/fuel mixture for optimal acceleration like when the engine is free reving. This like a built in road dyno maybe? It helps the ECU remember these fuel requirements for future use.
(4) It eliminates or over-rides the ECU's limiting the acceleration experienced in back-to-back full acceleration runs.
It definitely works better with my MY00 turbo than when I had an AFC. I still had to tune the fuel pressure for different amounts of boost, but the car at 5 psi and an untrained ECU with TCII (with and without using the electronic boost controller) was faster than when I had played with the AFC settings for three months!
Made so much power 2nd gear blew up at 9 psi... :-( See post entitled "9 psi boost + MY00 5-speed tranny = Bad Mojo -> No Go"
Larry
PS: Whomever says an IHI RB5 turbo doesn't allow you to make more than 230 hp is just dead wrong. This car is at least 250 at the crank and 200 at the wheels at 9 psi with everything we've done. Flame on
[This message has been edited by ImprezaRS dot com (edited May 15, 2001).]
ImprezaRS dot com is offline   Reply With Quote
Old 01-22-2001, 11:07 PM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
About how much does the TC II go for?
Old 01-22-2001, 11:55 PM   #4
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Post
Hmm. Yeah... got smoked by a '95 Legend tonight. I got him so bad off the line I only part-throttled it through 1st gear but then he stepped on it and after my 1-2 shift he went flying by... Where do I pick up this TCII? I want more power w/o going turbo just yet.
CosmoTheCat is offline   Reply With Quote
Old 01-23-2001, 06:54 AM   #5
subarumantoo
Member#: 3257
2000 ImprezaRS
Blue Ridge Pearl
Thumbs up
Thanks for the info Larry! I am about to purchase my IHI kit from JC Sports. I hope it comes with the TC2! If it doesn't, I'll be sure to add it to my kit.......
Old 01-23-2001, 05:48 PM   #6
Pimp-sube
Guest
Member#:
Cool
Still people are saying these chips are nothing more than a voltage clamp! Only the people who are running these chips understand how much of a difference they make, especially the NEW TC2!(retails for $325 and I bet NO-ONE can reproduce this chip...do I hear any bets?)
Kevin
Old 01-23-2001, 06:58 PM   #7
SnapperHead
Member#: 2740
Post
How would this TC2 effect a MY01 with headers, exhaust, cams and pulley? Would it be worth it?
SnapperHead is offline   Reply With Quote
Old 01-23-2001, 07:24 PM   #8
RidinLow
Member#: 329
1995 325i
Arctic Gray
Question
Kevin, why do you sometimes use a personal screen name instead of the JC Sports one? Just a little worried that it may mislead some people.
RidinLow is offline   Reply With Quote
Old 01-23-2001, 07:24 PM   #9
Niloc
Member#: 3296
99 2016 STI
Post
How do you think a car with a TCII would stand up to a car with a TEC II ?
[This message has been edited by Niloc (edited January 23, 2001).]
Niloc is offline   Reply With Quote
Old 01-24-2001, 12:20 AM   #10
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
How about some photos of the chip and what lines it intercepts to the ECU. So far I get that it set max voltage to 4.85 (or can) and can go limited fuel enrichment (less than a AFC can) plus somehow smooths out the spikes on various inputs to the ECU (the prevent retard on multiple WOT runs?)
just some guesses. Do you guys really know what this one does this time, or it it pay and pray still? Think you'd have more people interested if you had more detail and less snake oil.
Midwayman is offline   Reply With Quote
Old 01-24-2001, 07:06 AM   #11
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Post
I'm very curious as to what it does also. I'd be interested in buying one if the price went below $200 and someone freakin' knew what it actually does.
Thanks - Jon
omahasubaru is offline   Reply With Quote
Old 01-24-2001, 11:30 AM   #12
subarumantoo
Member#: 3257
2000 ImprezaRS
Blue Ridge Pearl
Post
Hey Larry, do you have the wiring diagram that comes with the TC2? I am so curious what this thing actually does.
[This message has been edited by subarumantoo (edited January 24, 2001).]
Old 01-24-2001, 03:41 PM   #13
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
Exclamation
Torque chip, id like one ,if its comin from JC sports, red flags go up.Check out the turbo thread in the vendors section.
My two cents,,Rudy
jagcars26 is offline   Reply With Quote
Old 01-25-2001, 11:18 AM   #14
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
For those that are planning on turbocharging your MY00+ (me) I would like to let it be known that JC Sports is no longer selling their basic "boost chip" and they now ONLY sell their $350 TC II. There goes the minimal piggy-back route eh?
Jon
Old 01-25-2001, 02:27 PM   #15
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
Will this cure the MY99 lean on top end with an intake then?
STiShawn is offline   Reply With Quote
Old 01-25-2001, 07:42 PM   #16
JC SPORTS
Guest
Member#:
Exclamation
OK, we've dropped the price to $250 for the Torque chip 2.
Snapperhead, the chip will benefit any 90-95 Auto and Manual Subarus and 90-2002 manual Subarus.
Ridinlow, I post under my personal name when offering my opinion. I dont feel it would be professional to state a personal opinion under the JCS name.
Niloc, The chip does nowhere near the engine management that the TEC2 does so it would not be fair to compare them in the same category.
Midwayman, we've explained numerous times that the chip is made for us exclusively by a fellow who takes quite a bit of pride in keeping his electronic skills secret(he guarantees that the chip cannot be duplicated by anyone!) However, Larry may be able to give you a more detailed description as to what its doing to improve his cars performance.
Jagcars26, Yes, we have/had numerous customer service problems, but we are also learning from our mistakes.
STIShawn, Ill ask the guy who makes the chips if it will cure the lean problem (Im assuming it will since Larry got rid of his S-AFC)
Hope I didnt miss anyone...Kevin
Old 01-25-2001, 07:42 PM   #17
96Lconversion
Member#: 3604
2008 Infiniti G35S
2005 S2000
Post
Would this chip work on a 96 2.2L with intake only???? worth it???
96Lconversion is offline   Reply With Quote
Old 01-25-2001, 10:18 PM   #18
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
I know the guy wants to keep his chip secret, but if he's so sure nobody can copy it, whats the harm of telling us exactly what it does. I mean we dont need part numbers, just what function on what line, at what RPMs. What settings if any, and a wiring diagram. That would be enough to let people make a more informed decision.
-B
Old 01-25-2001, 10:44 PM   #19
Niloc
Member#: 3296
99 2016 STI
Post
Kevin:
what I was wondering is if this chip could do anything that a TEC II can't?
Old 01-26-2001, 11:11 AM   #20
jdchmiel
Member#: 926
Post
is that a joke??
they are not comparable..
2k vs 250 is a big price diff..
the TEC II replaces all fuel /ignition functions of the engine..
If you dont do Shiv's parallel system, it replaces your entire ECU..
the torque chip is a bandaid.
I am not passing any judgement on it, just saying it is an add-on to "fix" the ecu...
any add on is a band aid. The more band aids you have and try to tune together, the more a complete engine management solution is needed.
jdchmiel is offline   Reply With Quote
Old 01-26-2001, 01:04 PM   #21
Max Umbarger
Member#: 1112
2006 FXT
RBP
Post
Why can't I see this chip on the jc sports site??
Max Umbarger is offline   Reply With Quote
Old 01-26-2001, 01:25 PM   #22
JC SPORTS
Guest
Member#:
Post
The chip is not just a band-aid it re-trains the stock ECU to adjust according to boost and fuel.
Kevin
Old 01-26-2001, 01:53 PM   #23
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
Kevin,
I PM'd you, please e-mail me. I have some questions about this.
[email protected]
Old 01-26-2001, 02:22 PM   #24
Haven
Member#: 95
2006 Wrx
Crystal Gray
Post
So for those of us who own a '99 rs auto are out of luck, there is no chip available???
Haven is offline   Reply With Quote
Old 01-26-2001, 02:34 PM   #25
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
I just talked to John at JC sports about these "chips". It is installed in the wiring harness, not to the ECU, it is emmisions complient (not CARB certified however), needs to be soldered into the harness and you must have an appropriate year wiring schematic. The Torque Chip one is a 4 wire affair and better for NA applications. The Torque chip two is for for turbo applications and is a 10 wire deal. The TC1's are in stock and the TC2's are a week out. Overall rather intersting. Might have to do this come spring or summer. Hopefully quicker delivery than the Turbo GB as they have them in stock.
NOTE: Im not slammin' JC Sports here, just a comment.
JC Sports Torque Chip II Problems Rainierez Engine Management & Tuning 2 04-19-2005 05:24 PM
I hate to cross like this, but need help with JC sports Torque chip JGard New England Impreza Club Forum -- NESIC 0 03-14-2001 04:00 AM
does any one have th jc sport torque chip zx2boy Mid Atlantic Impreza Club -- MAIC 0 03-05-2001 06:33 PM
does anyone have the jc sport torque chip zx2boy Legacy Forum 0 03-05-2001 06:10 PM
Anyone with experiance installing JC Sport Torque Chip II? yebokmj Normally Aspirated Powertrain 8 03-02-2001 11:58 PM
