Old 06-21-2004, 10:13 PM   #1
blackbeast23
Member#: 64286
1999 Impreza 2.5RS
Question Oxygen Sensors
I am in the process of turboing my 99' RS. Here is some background info... Before the turbo, I had the COBB Tuning Exhaust and Midpipe, with the Random Tech Hi-Flow Cat and Borla Headers. The Random Tech Cat had spots for both O2 sensors... one before the cat and one after. I also have the Pony Express check engine light eliminator.
While doing my turbo install, I noticed that my downpipe only has a spot for one O2 sensor. The downpipe connects to another pipe which then connects to my COBB midpipe. This pipe between my downpipe and the midpipe has no bung for another O2 sensor. Can anyone give me some suggestions as to what I should do? Is it alright to not connect the second O2 sensor?
blackbeast23 is offline   Reply With Quote
Old 06-21-2004, 10:40 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
you dont need the second 02 sensor, just keep the pony express in there though.
are you running catless with the turbo?
Jay
Old 06-21-2004, 10:45 PM   #3
blackbeast23
Member#: 64286
1999 Impreza 2.5RS
Yeah, I'll be running catless.
Thanks for your help!
Old 06-21-2004, 11:59 PM   #4
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
the pony express will do you no good without a functional rear O2 sensor. It won't affect performance at all, but you will get a CEL if the sensor isn't connected.
lotusTT is offline   Reply With Quote
Old 06-23-2004, 01:53 AM   #5
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
If you get a cat in-efficiency code due to the rear sensor being out, the ECU can lean out the mix under certain conditions to try and get the cat that it thinks is there re-lit. Something to be aware of.
no-coast-punk is offline   Reply With Quote
Old 06-23-2004, 08:53 AM   #6
Aphex
Member#: 146
'16 WRX Limited
could always get an O2 bung and get it welded in. under 20 bucks total probably.
Aphex is offline   Reply With Quote
Old 06-23-2004, 03:28 PM   #7
blackbeast23
Member#: 64286
1999 Impreza 2.5RS
That's what I'm having done today. I figure I should just do it the right way so I won't have to go back and fix something.
Front Oxygen sensor AKA air/fuel sensor swap out Peaty Tribeca Forum 0 02-20-2010 04:36 PM
2007 STi Rear Oxygen Sensor ( O2 Sensor ) Nitro Don Engine/Power/Exhaust 3 02-19-2009 11:49 AM
2007 STI Front Oxygen Sensor ( O2 Sensor ) Nitro Don Engine/Power/Exhaust 0 02-13-2009 02:16 PM
oxygen sensor vs air/fuel sensor paintbing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-02-2008 01:09 PM
FS: Front oxygen sensor 04 WRX 02 sensor Chino Bling Engine/Power/Exhaust 4 11-20-2007 11:56 PM
