Old 06-22-2004, 01:20 PM   #1
Barticus
Member#: 57709
97 Legacy 2.5 GT
green
Default egt
I have a stock wrx turbo on my 97 2.5 legacy gt (dohc). What kind of egt would be dangerous to exceed?
Barticus is offline   Reply With Quote
Old 06-22-2004, 01:33 PM   #2
crk4
Member#: 43617
1976 Ford Bronco
R.I.P. Mark Vos, 96 ob
If I recall correctly, I dont think you want to go over 1450-1500 degrees fahrenheit.
crk4 is offline   Reply With Quote
Old 06-22-2004, 04:19 PM   #3
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
the stock 2004 WRXs for some reason runs up to 1500s F because they leaned it out compared to previous WRXs. Not sure how the factory AFR goes on that WRX, but I think the egt bung was done at the downpipe for this.
Many also say anything over 1650s F on the cylinders will be bad.
STi-Nismo Dood is offline   Reply With Quote
Old 06-23-2004, 09:19 PM   #4
Unsung Boxer
Member#: 37196
yeah, you want to tune so that 1500 is about your max. 1450 is stoich.
I hear that 1600 is when your starting to get dangerious, which on most guages, they only go up that high.
I hope im correct, or my car has problems!
-Jake
Unsung Boxer is offline   Reply With Quote
Old 06-25-2004, 02:17 PM   #5
subieworx
Member#: 47769
1600* is the point at which aluminum (our blocks and head) start to melt. That is why you want to stay under that. I used to tune my Talon to 1550.
subieworx is offline   Reply With Quote
Old 06-25-2004, 05:17 PM   #6
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
not to contradict about keeping below 1600F egt, but have in mind that we aren't exactly just using aluminium since our blocks are aluminium alloy, also don't forget the coolant walls.
Old 06-25-2004, 05:20 PM   #7
subieworx
Member#: 47769
To clarify, straight aluminum starts to melt at 1600. Aluminum alloy will melt at a higher temp, say 1850, but that depends on the makeup of the alloy. Unless I know exactly what this engine is made of and what the specific beginning melting poitn is, I will stick to 1600 to be safe.
Old 06-25-2004, 05:54 PM   #8
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
Make sure you are taking yoru EGT readings in the manifold near the head. If not, add an extra safety factor. Tune to ~1500, and if you see more than 1550, fix the problem. And do a few more searches - don't take anyones word on here at gospel.
-Charlie
phattyduck is offline   Reply With Quote
Old 06-26-2004, 11:38 PM   #9
Barticus
Member#: 57709
97 Legacy 2.5 GT
green
thanks, guys
FS: S0-Cal--Prosport EGT (green/white) with Subtle Solutions ashtray delete preacher#1 Interior/Dressup/Audio & Security 9 06-25-2010 07:52 PM
autometer egt gauges, what egt probe are you using? Tobey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 07-09-2004 11:19 PM
Autometer Ultra lite EGT with oem egt probe? dubRexn Electrical & Lighting 2 09-17-2003 05:43 PM
will a defi egt probe fit into the factory uppipe egt location? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-08-2003 12:32 PM
what to do with uppipe factory egt if using defi egt whiterabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-21-2002 04:57 PM
