Old 06-22-2004, 05:06 PM   #1
I love my wrx
Member#: 64504
2007 421whp 406wtSti
Question Which O2 sensor is best for A/f gauge
I just bought what everyone calls an LED light show- Air to fuel ratio gauge and I was just wondering which o2 sensor and which wire to tap into on that o2 sensor. I have heard that the one in the manifold is a wideband and that it would give me a more accurate reading.
I love my wrx is offline   Reply With Quote
Old 06-22-2004, 05:23 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
True but you can't tap into that one. The gauge you bought can only be tapped into the rear narrowband sensor and is essentially useless for providing real AF readings.
If you want an accurate AF gauge the only way to go is a unit with its own dedicated wideband sensor mounted in the manifold.
Old 06-26-2004, 11:12 PM   #3
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
The techedge can send the wideband o2 sensor data to a narrow band gauge like an autometer.
Not sure why you would want to do it but it can.
LiquidForce is offline   Reply With Quote
Old 06-27-2004, 01:14 AM   #4
Rickyh
Member#: 40453
actually it has an output so that you can remove the factory narrowband and put the wideband in it's place.
Rickyh is offline   Reply With Quote
Old 06-27-2004, 01:59 AM   #5
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Where should the wideband be mounted in the manifold? I was just gona put mine in the DP, but my car has a bung about 3 inches from the turbo on the DP.
subiekid is offline   Reply With Quote
Old 06-27-2004, 09:33 AM   #6
LiquidForce
Member#: 12811
2002 2.5l Wrx
I have mine about 6 inches from the turbo. If you put it where the stock one goes it will be after the cat. I am not sure if or by how much it will throw off the readings. I know when dyno tuning they just stick a probe in the tail pipe.
Old 06-27-2004, 03:13 PM   #7
Big Turkey
Member#: 32118
If you put it too close to the turbo then you can risk the chance of the sensor getting too hot and getting inaccurate readings. I know alot of people stick it into the downpipe about 3-6 inches away.. I have mine right after my TXS DP in my midpipe, before the stock 02 sensor.
Big Turkey is offline   Reply With Quote
Old 06-28-2004, 04:22 AM   #8
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
buy an LM-1 wideband O2 sensor and set it up to output for your gauge.
cRayZee is offline   Reply With Quote
07 Sti: Which Catted Downpipe Is Best For a Protune? bballchris24 AccessPort 2 01-21-2010 06:22 PM
Which 3G phone is best for web surfing? RA29 Off-Topic 75 12-21-2008 11:57 AM
Which o2 sensor is the front, and which is the rear? jamesfacts Normally Aspirated Powertrain 4 07-06-2005 12:09 PM
A/F Gauge in a N/A, Which O2 sensor? Shakuwa Electrical & Lighting 0 04-05-2003 07:32 AM
Which aftermarket turbo is best for my application? Mr.Freeze Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-05-2002 09:27 PM
