Old 06-22-2004, 08:55 PM   #1
Unsung Boxer
Member#: 37196
Default Opinion on Boost levels
Important things:
- 2.2L na block (open deck) w/ EJ22t 8:1 internals, O-ringed head.
- WRX Turbo/Intercooler/Fuel Pump
- EJ22t 360cc Injectors
- Greddy Emanage
Currently at 12lbs of boost. But can I do more w/ this setup? I assume my injectors are the weakest link. Anyone thing its the block?
-Jake
Unsung Boxer is offline   Reply With Quote
Old 06-22-2004, 10:02 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
bump er to 16
if it blows
get a closed deck
Old 06-22-2004, 10:03 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
after new injs of course
get fat cat turbos
Old 06-22-2004, 10:17 PM   #4
Unsung Boxer
Member#: 37196
your no help @$$
Old 06-22-2004, 10:19 PM   #5
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Yum!
Maybe you can convince him to ship?
-Brett
ExecNav is offline   Reply With Quote
Old 06-22-2004, 11:13 PM   #6
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
12lbs is all i would be comfy with on that setup, maybe 13 if well intercooled, regardless of injectors.
no-coast-punk is offline   Reply With Quote
Old 06-23-2004, 01:13 AM   #7
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
this setup : 14
with 440 wrx injectors: 18
max tho...
HOK is offline   Reply With Quote
Old 06-23-2004, 01:29 AM   #8
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Originally posted by White 2.5rs
bump er to 16
if it blows
get a closed deck
you = stupid
with 360 injectors the most you can push is 13lb of boost. 16 lb and you will be running stupid lean.
You might look for some old school JDM 480 yellow top injectors. From what I have read they are a straight drop in, another local member has a jdm 2.0 and I want to try comparing them to mine to see if they work.
Also, nissan 300TT injectors fit into n/a legacy fuel rails, and the fuel rails bolt up to the ej22T so that might be another way to go.
What year is your ej22? Also, what intake manifold are you using?
subiekid is offline   Reply With Quote
Old 06-23-2004, 04:06 AM   #9
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
you moron i said w/ new injectors
Old 06-23-2004, 11:03 AM   #10
Unsung Boxer
Member#: 37196
Anyone concerned about the Open Deck? I used to, but then i htought about all the people w/ JE pistons pushing more psi on open decks.
All external engine parts are stock ej22.
The Head is o-ringed to maintain the head gasket.
I assumed fuel delivery is my biggest limiter right now, but i dont know what it would be after that.
-Jake
Old 06-23-2004, 01:19 PM   #11
subiekid
Member#: 25516
-Jake
people push fairly moderate levels of boostin the wrx and dont have any problems. With your cr I would think yoiu would be fine.
Old 06-23-2004, 04:25 PM   #12
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Originally posted by HOK
i've always had the opinion that a sturdy cylinder makes a happy piston... I have zero scientific evidence regarding this.. but the vibration and pressures at +20 psi just make a sleeved/closed deck block seem much more safe.
I would say anything lower then 250 hp you don't need to worry about the open deck issue. but anything over 300 or 20psi + on any (realistic) turbo i would do it as precaution. If you track it... i seriously would consider it.. but you are o-ringed... you may worry about the pistons before the block in your case..
Old 06-23-2004, 10:11 PM   #13
no-coast-punk
Member#: 49087
The issue with the open deck block isn't what boost levels it will hold before exploding, but what you can subject it to before turning the cylinder liners from nice circles into nice ovals. It will happen on any open deck engine given enough time especially if you track the car and see prolonged boost. This is why just about everyone with a 2.5 RS-T is having massive blowby issues and big compression losses after 30,000 miles or so if they are seeing boost frequently, regardless of how good their tuning is or how much boost they are running. I'm not sure about the 2.2 NA block... but I think the rod/stroke ratio might generate slightly less sideloading. If you had a good engine machinist weld bracing into your block in strategic places you could run ALOT of boost for a long time with no issue... but you will always be fighting an uphill battle with the flexi-ness of the open deck.
Old 06-24-2004, 12:06 PM   #14
crk4
Member#: 43617
1976 Ford Bronco
R.I.P. Mark Vos, 96 ob
What is the fuel adjustment with the 360cc injectors and the E-manage? Have you maxed them out up to 50%?
Just wondering bc I'm in the market for some high flow injectors and I'm thinking something bw 400 and 500 cc but I'm not sure. I got the 96 2.2 NA engine...not sure if the injectors are the same as yours but they should be...side feed.
Side note:
Do you track the car? What does it run if it does? Just curious what kind of times and what kind of cars you beat.
crk4 is offline   Reply With Quote
Old 06-24-2004, 02:36 PM   #15
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
wow...8:1, huh? Is that stock for the Legacy Turbo motor?
If it is...SWEET. I thought they were 9:1...
BTW, I'm doing the same swap in July...vrrrooom!
//marcus
marcus12 is offline   Reply With Quote
Old 06-24-2004, 10:49 PM   #16
crk4
Member#: 43617
1976 Ford Bronco
When you get bigger injectors, I will glady purchase those EJ22T ones from you.
Old 06-25-2004, 11:06 AM   #17
Unsung Boxer
Member#: 37196
emanage is idling at -37%, and max boost i hit -20%... its all about the scale. Im not using auto correct.
8:1 is the CR... i think sometimes that mine might be lower, using EJ22na heads and head gasket. who knows???
I dont track the car yet, funny u ask, cuz i was gonna go soon.
Crk4 ill let u know when i get larger ones. I think u need my fuel rails too
-Jake
Old 06-25-2004, 12:58 PM   #18
crk4
Member#: 43617
1976 Ford Bronco
OK, I wasn't sure whether I needed the fuel rails too, but I have the option of buying them from Kostamojen now since he's parting out his kit, so I guess I will buy that.
So how hard was the E-Manage to learn how to tune? And did you have previous experience with tuning before that? I see it says you are an automotive tech so you probably know everything about AF ratios and timing.
-Chris
Old 06-26-2004, 01:30 AM   #19
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Question fuel rails
hhmm fuel rails...@ about what power level should one start thinking about upgrading fuel rails? I have heard my 98 rails lean out cyl #3...is this the only problem?
IllNastyImpreza is offline   Reply With Quote
Old 06-26-2004, 11:52 AM   #20
Unsung Boxer
Member#: 37196
-Chris
I wont likely seperate the injectors from the rails when i sell them.
Emanage is easy to work w/, but tuning is another thing. it doenst tune for you. Im a relatively new tech, and i dont have the equipment to do acurate tuning anyways... so i wont make any claims, ha ha!
-Jake
Old 06-26-2004, 04:03 PM   #21
markus
Member#: 438
2004 STi
White on Gold
Who's car(s) is doing what you describe??? I thought that old "Built" EJ25's were running fine with open deck and 14-17 psi??? Curious as to your experience here.
Thanks.
MB
markus is offline   Reply With Quote
Old 07-06-2004, 06:26 PM   #22
flathead
Member#: 63047
1995 legacy wagon
alpine white
cobb told me 10-12 psi with n/a 2.2, proper tuning and proper internals.
Subaru in parts, John, said 2.2 n/a injectors put out max. same as 2.5
2.2 turbo exhaust valve fits the n/a head. 2.2 turbo intake valve is actually smaller.
connecting rods are same between blocks.
What head gasket did you decide to go with?
flathead is offline   Reply With Quote
Opinions on using OEM subwoofer speaker leads as high level inputs for single amp/sub 02BlueSuperRoo Car Audio, Video & Security 6 06-03-2006 08:44 PM
Q on boost levels kip Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-20-2006 05:49 PM
boost levels on stock/modified wrx WRX'R X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-25-2002 10:55 PM
How do you raise boost levels on the WRX? mastervic27 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-02-2001 06:04 AM
