Old 01-26-2001, 08:25 PM   #1
Robmat
Member#: 2173
2000 2.5 RS
BRP
Question Rough idle after oil/spark plug change?
Anyone have any suggestions? After the oil- spark plug change the car (MY00) is a bit shaky at a still idle. I didn't notice it before the change. I used the reccomended NGK plugs, a Mobile1 oil filter, and Castrol Synthetitic blend. This was my second oil change and first time for the plugs. I reset the ECU after changing both. I hope you guys can help! Thanks:
Robmat
Robmat is offline   Reply With Quote
Old 01-26-2001, 09:42 PM   #2
SkToBe
Ghost Mod
Member#: 1278
2001 RS
Post
Did you make sure all the plug boots are seated firmly? Only thing I can think of...
SkToBe is offline   Reply With Quote
Old 01-26-2001, 11:16 PM   #3
Jason
Member#: 105
2000 Legacy GT Ltd
WHT
Post
Spark plug gap?? or check wire connection.
Jason is offline   Reply With Quote
Old 01-27-2001, 08:24 PM   #4
Bruce Feinberg
Member#: 3447
Post
Make sure the oil level is not overfilled. Also, make sure all the hoses are hooked back up(in our shop I've seen people come in with this symptom after changing the air filter-the smaller hose to the air filter hosing was off-it throws the whole injection system out of whack).
Good Luck
Bruce Feinberg is offline   Reply With Quote
Rough idle after changing out spark plugs, help? ctkeith Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-07-2009 08:57 AM
rough idle after cam seal change *videos* Matt4545 Normally Aspirated Powertrain 9 03-16-2009 05:15 PM
Oil temps after Spark-plug change AmolaitoPR Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-08-2006 11:27 PM
1993 Subaru Impreza burning oil at idle after oil change Joe Pollock Service & Maintenance 3 08-15-2005 11:15 PM
Help! CEL On after Spark Plug change minx Service & Maintenance 5 01-08-2002 05:33 AM
