Old 06-22-2004, 11:05 PM   #1
ImportVenom
Member#: 34204
2004 WRX
WR Blue
Default Will Auxiliary Boost Controller fix Cobb AccessECU/AccessPort low boost issues?
Hey all, I emailed Trey about this a while ago but haven't gotten a response. The UTEC uses an auxiliary boost controller (ABC) to help reach desired boost levels. Is this something that those of us with AccessECU low boost issues should try out? Specifically, a friend has told me that the factory boost controller is not capable of reaching target boost levels in certain environments, such as high altitude.
Here's a NASIOC post I found about the ABC:
"I have a TurboXS Stage II kit (Unichip) and it uses an ABC (Auxiliary Boost Controller). The ABC is a bleed valve that allows the stock solenoid to hold higher boost. The Stage II Unichip was tuned for 16psi (or so I was told since TurboXS has not responded to my emails about the Unichip). IMO, the ABC's advantage over the MBC is that it will only produce full boost at WOT."
My main question is whether this would cause any problems with the Cobb ECU. It seems that the ABC was designed specifically for altitude and weather variations.
ImportVenom is offline   Reply With Quote
Old 06-23-2004, 12:14 AM   #2
RussB
Guest
Member#: 43667
it would fix the problem, but it's probably not the best way to do it. Cobb offers HWG (higher wastegate duty cycle) maps for Stage 1 and Stage 2 AccessPort reflashes that will help you hit the boost target. That is probably the best way to go about it. The ABC will effectively increase the wastegate duty cycle, but it does it mechanically by bleeding off a little pressure.
RussB is offline   Reply With Quote
Old 06-23-2004, 12:22 AM   #3
ImportVenom
Member#: 34204
2004 WRX
WR Blue
The problem is, the HWG maps don't seem to make much difference at all. Maybe 0.5 psi at most. But I am about 2 psi below the target boost levels. I also tried adjusting the wastegate arm actuator, and that didn't help either. I believe it's the elevation (6k) that is making the car not be able to hit target boost. Would an ABC be the solution, or a custom map from Cobb?
Yet another Cobb 2.5 low boost issue eatsrice Engine Management & Tuning 10 08-29-2005 11:16 AM
Ultimate fix for Cobb stage 2 low boost problem... WRXVII Engine Management & Tuning 37 07-31-2004 03:44 AM
Cobb stage 2 low boost problem - anyone found a fix yet? txl146 Engine Management & Tuning 11 05-28-2004 12:34 AM
Cobb stage 2 low boost problem - let's put this to an end! READ THIS! txl146 Engine Management & Tuning 1 05-23-2004 10:56 AM
cobb stage 2 low boost CrashN2mee Engine Management & Tuning 15 03-10-2004 11:03 AM
