Old 01-26-2001, 08:54 AM   #1
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
Post Borla Check Engine light possible fix
I dont have a Borla header on my baby yet. Dont know if I ever will. But I have been reading the problems with the CE light that seems to have possibly found a cure. Keep the heat in the pipe. I have not checked up on the posts lately for that topic, but a few guys have tried it and that solution seems to have done the trick, for now anyway.
What I wanted to tell the Iclubbers here, is a service that we old hot rodders (I'm 27, so old is not the best term I guess) used to keep under hood temps lower, and exhaust gasses nice and hot and free flowing.
Its called Jet-Hot. Its a coating that is applied to the inside and outside of your header. Its a ceramic based coating from 1 mil to 5 mils thick, and can dramatically reduce the amount of heat lost out of the header without the need for header wrap and other coverings.
The only catch is that you have to send your header to them to get it coated. But you can choose the color of the coating (to an extent) and even get a kick butt looking polished aluminum look to them, that WILL NOT COME OFF.
If keeping the exhaust gasses nice and hot so the cat can work is the solution to the borla header problem, then this company might just do the trick for an additional added cost.
the websight is
www.jet-hot.com
Anyway just wanted to help out you guys with Borlas, because I will not buy one until the problems is completely fixed!
SCRAPPYDO
stephen
SCRAPPYDO is online now   Reply With Quote
Old 01-26-2001, 02:21 PM   #2
Greborb
Member#: 2974
Post
Thanks scappydo....understand it's quite pricey though?
Greborb is offline   Reply With Quote
Old 01-26-2001, 07:00 PM   #3
Member#: 67
1999 Outlasting
the competition.
Post
Scrappy email me. i have some questions for you
[email protected]
Old 01-26-2001, 07:55 PM   #4
S.Damery
Member#: 1770
Post
I wrote to Jet-Hot earlier this week about prices etc. here's their reply:
"The price to coat a 4cyl header in&out with the sterling silver finish is $165+$18s&h back.Add $20 for the flat black,blue or grey finish"
I'm seriously considering getting this done when I get my headers. A bit pricey I know, but it's also supposed to help a bit with exhaust scavaging which may be worth a couple of HP itself. Hope this helps.
-Shawn
[This message has been edited by S.Damery (edited January 26, 2001).]
S.Damery is offline   Reply With Quote
Old 01-26-2001, 09:20 PM   #5
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Talking
I had jet hot coated headers from calmini on my geo tracker. It never had a problem with CE lights, but there was only one cat and one O2 sensor. It also passed emissions.
Somebody try it ! Will the metal corrode any faster or slower with it on? The headers never cracked in the two years I had them on. It didn't even have a flexpipe. There was also never a problem in colorado's cold weather with the check engine light either.
Food for thought.
Gary
HamFist is offline   Reply With Quote
Old 01-26-2001, 09:26 PM   #6
tluzziracing
Guest
Member#:
Post
jet-hot is the best!
worth every penny.they charge $10 per/ft.
Old 01-26-2001, 09:47 PM   #7
25psi
Member#: 3086
2001 2.5 RS
Post
Where had you been guys????
Jet-Hot rules and been around for ages!!!
There also are similar others but this one surely oldest.
Eugene
25psi is offline   Reply With Quote
Old 01-26-2001, 10:46 PM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
Tluzziracing has the important point - it's $10 per foot, it's not just a blanket "4 cyl headers cost $xxx". Keep in mind that because of our engine's layout, and the way the Borla headers are set up, our header pipe is waaaaay different than the typical 4 cylinder header. So, I would guess that the estimate they gave Shawn is probably low.
There are a number of companies that do metallic-ceramic coatings, and from what I've gathered they're pretty much all the same. They all say their stuff is rated to 1300degF, and they all offer a 3 year warranty. Check out http://www.i-club.com/ubb-files/Foru...ML/001172.html for a couple other links to companies that do metallic-ceramic coatings.
As I said in that link above, I intend to get my MRT header coated by Air Born Coatings www.airborncoatings.com as soon as my exhaust system arrives. Air Born has a branch only an hour from me, and their prices seem a bit better than Jet Hot, so I save on shipping and on the coating itself. There's also a little bit of a difference in warranty coverage - Jet Hot offers a 3 year 100% satisfaction guarantee, and a lifetime rust-through guarantee. I'm pretty sure when I called Air Born the guy told me they offer a lifetime 100% satisfaction guarantee. I'd rather not have to wait for a part to completely rust through before I can get it fixed, so I like Air Born's warranty better.
I don't know if the metallic-ceramic coatings will cure the CE light problems that people have had, but they will keep your headers looking very sharp and corrosion/discoloration free pretty much forever.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 01-27-2001, 07:48 AM   #9
S.Damery
Member#: 1770
Post
Pat,
How much is Airborn coatings going to charge?
-Shawn
Old 01-27-2001, 07:19 PM   #10
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
Here's some interesting reading on the subject:
http://www.performancecoatings.com/Review.htm
gavin is offline   Reply With Quote
Check Engine Light Mechanical Fix $12 Shipped! Mr. Quick Private 'For Sale' Classifieds 0 12-03-2005 10:44 PM
Evail Motorsports catless exhaust check engine light fix. Destroy Vendor Reviews 0 01-11-2003 07:12 PM
Check engine light fix. shedrick Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-15-2002 07:02 PM
Check Engine Light fixed... Dirt Man South East Region Forum 7 02-20-2002 05:07 PM
Check engine light/noisy startup rattle fix blaster88 Normally Aspirated Powertrain 1 02-04-2001 07:43 PM
