Old 11-09-2000, 07:18 PM   #1
tluzziracing
Guest
Member#:
Post how to pull diagnostic codes from ecu?
keep getting a check engine light on my 00rs
anyone out there know how to get it into diagnostic mode to get the flashes on the check engine light?
i did a search first and had no luck.
also i went on to mrt's web site and their technical part said connect the green and black plugs under dash together (grn to grn,blk to blk) start car drive 1 minute,and it will flash the pulses.
if it flashes steady half sec. pulses then there is no code stored.
my car only has the grn plugs and every time i try to pull the code it flashes half sec. steady.........
but yet my ck engine light comes on.
any help would be great...
thanks
tony
[This message has been edited by tluzziracing (edited November 09, 2000).]
Old 11-09-2000, 07:28 PM   #2
tulit
Member#: 338
09 STi
Post
Not sure if the Subarus have a way for them to "flash" whats wrong.
You may need to find someone with a OBD scan tool and have them pull the codes for you.
Generally speaking, if its a new car, this should be covered by the dealer!
tulit is offline   Reply With Quote
Old 11-09-2000, 09:42 PM   #3
tluzziracing
Guest
Member#:
Post
bump
Old 11-09-2000, 09:45 PM   #4
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Sounds like a dying O2 sensor to me... in any case, I'd take it back to the dealer!
RidinLow is offline   Reply With Quote
Old 11-10-2000, 07:56 AM   #5
BG5
Member#: 695
Post
try http://www.obd-2.com if you want to DIY.
That plug underneath will put it into a diagnostic mode (will retest everything), remember that OBD isn't mandated outside the USA, so I would imagine they use different ECU's with different diagnostics.
BG5 is offline   Reply With Quote
Old 11-10-2000, 09:12 AM   #6
tluzziracing
Guest
Member#:
Post
thanks everyone.........
Old 11-10-2000, 10:05 AM   #7
RandyF
Guest
Member#:
Thumbs up
I have the OBD-2 connector for a laptop from OBD-2.com ... very cool and works very well...
A
Old 11-10-2000, 08:51 PM   #8
tluzziracing
Guest
Member#:
Post
that web site is great.....
im going to buy the scan tool,looks like it will be very usefull.
thanks
tony
How to pull abs codes from 96 impreza? simpreza2 Brakes, Steering & Suspension 0 09-04-2004 01:21 PM
How to pull CEL code? PeteDucati Engine Management & Tuning 3 03-18-2004 09:36 PM
how to pull cel codes? no_rex_yet Service & Maintenance 3 01-17-2003 05:55 PM
Pulling diagnostic codes? 4degrees Newbies & FAQs 1 08-11-2002 02:50 AM
Need to pull error code from ECU local... hayscoob Bay Area Impreza Club Forum -- BAIC 1 03-21-2002 01:52 AM
