Old 06-23-2004, 01:18 PM   #1
Stubaru
Member#: 2073
07 Volvo S60R
Cthulhu Gray
Default Copper Gaskets
Ok, I understand that copper gaskets leak oil on N/A motors (and most times on all types of motors) because of different expansion coefficients. Apart from the leaking, are they a suitable/reliable replacement for say, the 98 EJ25 DOHC motors that have blown head gasket issues?
Also, how much oil is lost through the leaking on the average set of copper gaskets?
Cheers,
Stu
Stubaru is offline   Reply With Quote
Old 06-23-2004, 11:12 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Are they available?
Tim Sanderson is offline   Reply With Quote
Old 06-24-2004, 09:17 AM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
On a street driven car, I probably wouldn't recommend them. They're meant to hold higher compression better. On a stock motor.....why bother with the headaches of leaking oil and other BS....
Legacy777 is offline   Reply With Quote
Old 06-24-2004, 02:09 PM   #4
Section 8
Member#: 821
Rarely are copper gaskets available "for sale". You usually have to provide a gasket to someone who will cut you a copper gasket.
See if Cometic has gaskets for the DOHC, I am almost positive that they do.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 06-24-2004, 02:17 PM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
use the cometic ones or i am sure a 2004 STi one would work.
Jeremy
Old 06-25-2004, 10:21 AM   #6
Stubaru
Member#: 2073
07 Volvo S60R
Cthulhu Gray
I think that the leaking would still be better than having the head gasket constantly replaced since they charge almost $1500 for the service.
Stu
Old 06-25-2004, 11:50 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Stu
no because after time even the copper will start to leak coolant and then you are back to square one
Old 06-25-2004, 02:36 PM   #8
Stubaru
Member#: 2073
07 Volvo S60R
Cthulhu Gray
oh, see I didn't know they leaked coolant. Is there a happy meduim between copper and what we use now?
Stu
Old 06-25-2004, 02:47 PM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
3 or 4 layer steel
Old 06-25-2004, 03:19 PM   #10
Storm
Member#: 5218
96L Most Over-
Developed Beater
Cometic has gaskets for the DOHC. PN's as follows:
C4264HP= .043" MLS 100mm DOHC suitable for boost/nitrous.
H16310275=.027" MLS 100mm DOHC.
I actually have a set of the C4264HP gaskets for sale if anyone is interested, $110 shipped.
Jay Storm
Old 06-26-2004, 05:05 PM   #11
Stubaru
Member#: 2073
07 Volvo S60R
Cthulhu Gray
Can you explain those dimentions, I'm assuming one is thickness?
Stu
Old 06-26-2004, 06:53 PM   #12
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Stu - The latest 4-layer DOHC gaskets seem very durable. I blew two sets of the original 3-layer gaskets, once at about 59k, then again at about 75k. That was with an all stock motor. I've now got about 50k (I think - I'd have to go check my service records) on the 4-layer gaskets, which were installed at the same time I did my Cobb heads and cams. I've had zero problems with these gaskets, and the car has certainly seen plenty of abuse.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 06-27-2004, 04:26 AM   #13
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Gaskets
Paeco Industries sell copper gaskets for our cars. I purchased a set sometime early last year when I was going to have some work performed at ILP Performance. I dropped them off at ILP and I haven't seen them since.
They weren't the best looking headgaskets but they were copper. I just never had a chance to use them.
Kevin Thomas is offline   Reply With Quote
Old 06-28-2004, 08:20 AM   #14
Stubaru
Member#: 2073
07 Volvo S60R
Cthulhu Gray
Patrick,
If you put the cobb heads on, did cobb change anything that would make the gaskets blow less? People have been saying that the heads actually warp due to poor cooling or some other design flaw.
That being said do you know the part number for the 4 layer gasket?
Cheers,
Stu
Crucial Racing copper gaskets dbrier Car Part Reviews 6 09-17-2008 10:04 PM
Copper Gasket Maker for the Hard-to-Find Single Port Gaskets. Hites Normally Aspirated Powertrain 7 09-06-2007 02:18 PM
Copper Gaskets vs. OEM Gaskets scoobydrew06 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-27-2007 04:59 PM
Crucial copper gasket and gasket spray questions athakur999 Newbies & FAQs 4 12-23-2005 01:04 AM
Copper Gasket Questions Stubaru Normally Aspirated Powertrain 7 01-11-2003 09:09 AM
