#1 |
Member#: 2672
Vehicle:1973 Porsche 914 Porsche Red |
I have an MY00 2.5RS and I ordered the Subaru engine block heater from my dealer. I was wondering if anybody has this and could tell me how to hook it up to the engine? I looked under the hood and couldn't see anything apparent that I would hook it up to. I also looked in the car manual, and it didn't have anything to say.
Any help would be appreciated! Thanks, Tom Richardson, Jr.
#2 |
Member#: 1234
Vehicle:2000 |
The block heater will fit into one of the frost plug holes, little circle plates. Inorder to put the block heater in you will have to knock out the frost plugs and remove them. Oh besure that the coolant is drained and not too hot. Then put the block heater. I suggest that if you do not really need it, don't put it in. This is because they always leak in the future when they rust out.
PS I suggest you let a mechanic install it if it sounds to complicated. |
#3 |
Member#: 2672
OK, thanks. I think I'll be able to figure it out now.
Oh, I need it. Today when I went out to start my car it was 15 degrees F. I live in Hailey, Idaho. It gets pretty darn cold here in the winter. Thanks! Tom Richardson, Jr. |
#4 |
Banned
Member#: 2641
Vehicle:2000 Impreza 2.5 RS Dirt and Bird Poop |
15 F????
You call that cold??? I'm still wearing shorts until it hits single digits. Hell, my carbed isuzu pickup would even start first try at 15F --Roy |
#5 |
Techno Sapien
Moderator Member#: 449
Vehicle:2010 Legacy 3.6R Lim Azurite Blue Pearl |
There is an engine coolant plug on the drivers side bottom or the engine. You'll need a 14mm allen wrench to get it out. It's not a freeze out plug but something that needs to be unscrewed. Obviously you'll have to drain the coolant first. That plug is in there really tight. I tried using a 14mm bolt with 2 nuts jammed together but I still couldn't get the bugger out. The nuts kept moving. If you want to see the exactly what the plug looks like go here: http://www.azscooby.com
and look at the OEM oil cooler mod. I had to remove the same plug but on the oppisite side. Peaty [This message has been edited by Peaty (edited November 10, 2000).] |
#6 |
Member#: 46
Vehicle:2001 Jetta 1.8T White |
Tom,
Get one installed before the winter gets too bad. It was -4F today and the car fired up great. I have the engine block heater and a batter heater. Any ?'s e-mail me. Eric PS - Don't forget to unplug the car before you drive away. |
| Thread Tools | |
| Display Modes | |
| Question: Reparing engine block heater cord | John Callahan | Alaskan Impreza Club Forum -- AKIC | 14 | 11-21-2005 01:32 AM |
| Engine block heaters, do they work? | SOneil0387 | General Community | 18 | 01-03-2005 11:19 PM |
| SOA engine block heater | darioc | Interior & Exterior Modification | 4 | 12-07-2004 06:56 PM |
| Subaru Engine block heater brand new | Bear | Private 'For Sale' Classifieds | 1 | 09-15-2003 10:18 PM |
| Subaru engine block heater install - need HELP! | Peaty | Normally Aspirated Powertrain | 2 | 11-17-2000 12:42 AM |
