Old 11-06-2000, 01:32 AM   #1
tabolau
Member#: 1044
2000 Impreza 2.5 RS
Post I had an Eclipse GSX turbo, is it ok to use it in my suby???
Hi, my friend just changed his turbo on his GSX. So I will take his turbo for my suby!!! Is it OK??? I don't want a lot of boost, for me 5-7 psi is OK!!! Is it very hard to custom the piping and other things? I wanted to get the whole kit, but I don't have that kind of money. I just checked out JC-Sports' turbo, the cheapest one on the websit is $3500 with IHI turbo. BTW, I have MY00. Thanks for your help!!!
Henry
[This message has been edited by tabolau (edited November 06, 2000).]
tabolau is offline   Reply With Quote
Old 11-06-2000, 04:13 AM   #2
bill harvey
Member#: 10
2005 Legacy Gt wagon
Garnet red pearl
Post
go to the new england forum and talk to efoo he has one on his rs
bill harvey is offline   Reply With Quote
Old 11-06-2000, 04:49 PM   #3
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Thumbs down
If you are talking about the stock turbo for a 2nd gen. GSX (Garrett T-25) then I would recommend against it. It is way to small for the low compression (8.5:1) 2.0 litre motor in the GSX. It will definitely be way too small for a higher compression 2.5L motor. Now, if it is from a 1st gen car, it is bigger and may work for low boost applications.
peepshow is offline   Reply With Quote
Old 11-06-2000, 05:15 PM   #4
GoFast
Member#: 2825
Post
dsmawd...is that the T28?
GoFast is offline   Reply With Quote
Old 11-06-2000, 11:19 PM   #5
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Post
GoFast, no it is the 14B, the T-28 was not OEM on any DSMs that I know of. The 16G is OEM on the Lancer Evos.
Old 11-07-2000, 05:46 AM   #6
Ch˙SacSVT
First RS in the 12's YEEEEEEEEEHA!
Member#: 129
'03 Corvette Z06
Black as in:180mph Black!
Post
First of all you didn't mention which year the GSX was....
I have 12yr experience working with different turbos, 90% of 'em Mitsus.....
so I'll try to help u guys...
The T25 turbo is the stock turbo on the latest GSX-GST (95-99), since the car has a little more compression (8.5:1).
The first generation 89-91 used a mitsubishi TD05H turbo, also on the 92-94 models (89-94 7.8:1 C/R).
The upgrades for these cars are the TD05H-16G, the TDO5H-20G, TDO6 (the one I used!!) & the Frankestein models. Also the stock turbo on the Lancer is in fact a Mitsubishi TD05H-16G with Titanium turbine & compressor wheel, which u might NEVER see on the aftermarket!!
BUT.....the 22b uses an upgraded version of the T28...
If the turbo was from a 1st, Gen. It will work very nicely, in fact a lot of people are swappin' older turbos on the 2nd gen cars.
If the turbo is from a 2nd gen, it will be even easier. Just change a few parts & convert it to T28 in no time, since the T28 is an upgraded version of the T25.
Also Garrett parts should be available at your local drugstore, no Rx needed! .
T3-TO4 are way too big for our cars, the engine falls short on the rpm demand.
The biggest a turbo scooby should go is a T3-Super 60 hybrid, which in fact it's my next project!!!!
If u need more help, just let me know...
GOOD LUCK!!!
Ch˙SacSVT is offline   Reply With Quote
Old 11-08-2000, 12:10 AM   #7
tabolau
Member#: 1044
2000 Impreza 2.5 RS
Post
Thanks guys,
I have the second generation turbo the T-25 I think. It came from 98 Eclipse GSX. How do I upgrade it??? What parts should I use??? Also, I know that the wastegate of this turbo does not work, is it a big deal?? or I can just change to the other one!!! It is an internal wastegate!!! Thanks for your help!!!
Henry
[This message has been edited by tabolau (edited November 07, 2000).]
just put my new mods on/ is it ok to drive it to get dyno tuned? vpr88 Newbies & FAQs 6 05-20-2010 09:28 PM
Is it ok to use Mothers Billet polish on my exhaust? OBPStiInMyEye Car Care & Detailing 12 05-31-2009 07:22 PM
Is it ok to use different brake pads for F & R? Hank3 Brakes, Steering & Suspension 11 08-17-2004 02:56 PM
Is it ok to use a term of endearment for more than one SO? ent2b Off-Topic 15 11-17-2003 09:19 PM
Is it ok to use Morette headlight in CA? aek Bay Area Impreza Club Forum -- BAIC 3 06-11-2002 09:19 PM
