Old 06-24-2004, 02:28 PM   #1
inpreza kid
Member#: 3334
Default how good is the stock coilpack/ignition?
the stock 2.5RS puts out about 165hp flywheel. most RS-T guys are putting down close to double that number with bolt on turbo kits with a standalone and even more with built motors. i've always wondered if the stock coilpack could keep up providing a strong spark. for upgrades, most standalones can run aftermarket external ignitors and direct fire coilpacks in wastespark mode. the only non stock coil/ignition system i've seen used on the 2.5RS is the tec2/3 systems. any thoughts on this?
inpreza kid is offline   Reply With Quote
Old 06-24-2004, 02:54 PM   #2
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
There have been threads about this, and they've mentioned that the stock coilpacks are actually pretty good and do not need to be replaced when doing said upgrades.
cRayZee is offline   Reply With Quote
Old 06-24-2004, 03:05 PM   #3
inpreza kid
Member#: 3334
i have read a lot of those threads. most of them were of people asking msd for ignition upgrades and msd stating the stock system was good enough as a reason for not having any sort of upgrades. i'm looking for more factual infomation.
Old 06-24-2004, 05:20 PM   #4
spiralsmurf
Member#: 16085
2005 STi
people run 400whp on WRX with stock coilpacks. is that factual enough?
spiralsmurf is offline   Reply With Quote
Old 06-24-2004, 06:09 PM   #5
inpreza kid
Member#: 3334
wrx/sti also has different ignition system. they run individual coil pack/ignitors on the end of each spark plug.
Old 06-24-2004, 06:16 PM   #6
spiralsmurf
Member#: 16085
2005 STi
i believe the RS also have 4 coilpacks just not mounted on the plug.
Old 06-24-2004, 06:23 PM   #7
inpreza kid
Member#: 3334
the 99+RS unit is two coilpacks put together firing in wastespark with a built internal ignitor. i was under the assumption the wrx/sti fired straight direct fire. not too sure on that..
Old 06-25-2004, 12:56 AM   #8
sick1.8t
Member#: 22345
2003 RSX
black
if you do a search for the big wrx power threads, look at all the guys putting down 400-500+ hp to the wheels. i've been following these threads and dont remember anyone ever using an upgraded ignition.
sick1.8t is offline   Reply With Quote
How long is the stock turbo good for? hizzity Newbies & FAQs 5 10-19-2009 10:49 PM
how good is the security system on the wrx/sti??! f1mania Car Audio, Video & Security 2 08-06-2004 09:20 PM
how good is the Stock WRX cd player? wagonman Car Audio, Video & Security 1 11-01-2002 03:25 PM
How good is the stock WRX suspension with good wheels and tires? SCRAPPYDO Brakes, Steering & Suspension 30 01-13-2002 02:48 AM
how good is the stock wrx?? dopey_one Car Audio, Video & Security 7 06-05-2001 11:36 PM
