Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 06-24-2004, 02:29 PM   #1
csleee
Member#: 17861
Default noise with ground control/koni
there is a loud ticking type sound coming from my front right side. it used to be on the front left but went away and seems to come back everytime i try and raise the car with a jack. the noise will go away when i apply brakes but will come back if i let off. it seems to get louder as i drive the car longer and gets really annoying.
anyone know what this is?
csleee is offline   Reply With Quote
Old 06-24-2004, 04:25 PM   #2
csleee
Member#: 17861
come on someone help me
Old 06-24-2004, 04:27 PM   #3
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
i would put this same post in brakes/suspension forum
you'd get a lot of answers there.
OneArmedScissor is offline   Reply With Quote
Old 06-24-2004, 04:33 PM   #4
csleee
Member#: 17861
i did and got nothing
Old 06-24-2004, 08:48 PM   #5
D_REX
Member#: 8945
MY02 WRX
Does the ticking noise change rate with speed? Is it stil present while turning? Do you have to really brake or just push on the pedal a little bit?
Without more details I'd guess that it's your brake pads or maybe the clips that hold them in place. If it happens at low speeds you can have someone drive your car around a parking lot while you try to localize the noise from outside. You can also try putting the car on jackstands and turning the front tires.
Later,
Dustin
D_REX is offline   Reply With Quote
Old 06-25-2004, 01:43 AM   #6
csleee
Member#: 17861
well i localized the noise to the front right wheel. I have only heard the noise until i put the new suspension in. at first it was in the front left, but then it went away and i didnt hear it until i raised the car again. i dont have to brake hard at all, just a little bit of pressure and it goes away. the ticking rate increases with speed but seems to go away at higher speeds. it seems like its less while turning. only reason i think that it is suspension is because i have only heard it since my new suspension and the sound moved from the left to right.
Old 06-25-2004, 02:20 AM   #7
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Possible brake pad movement in the caliper bracket?
Did you use the anti-rattle clip?
BlkTS02 is offline   Reply With Quote
Old 06-25-2004, 02:26 AM   #8
csleee
Member#: 17861
what anti-rattle clip?
Old 06-25-2004, 02:28 AM   #9
BlkTS02
Member#: 50142
2002 2.5TS
MBP
it's a sliver clip that's about an inch long. Mounts onto one of the pads.
Old 06-25-2004, 02:32 AM   #10
csleee
Member#: 17861
i didnt touch the pads or anything besides the brake lines
Old 06-25-2004, 02:35 AM   #11
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Judging by what you described, I'm thinking something with the brakes.
How old are the pads, rotors? Is everything clearing? Are the brake lines contacting anything?
Work methodically and eliminate one part at a time.
Old 06-25-2004, 09:02 AM   #12
D_REX
Member#: 8945
MY02 WRX
Originally posted by BlkTS02
Are the brake lines contacting anything?.
This is a really good suggestion. Do you have SS brake lines? To install your suspension you would have had to mess with the brake lines.
The clips BlkTS02 is talking about are actually wear indicators. There are 2 anti squeal shims on the back of each pad though. Another culprit could be the spring clips that hold the pads in the brakcet while the claiper is off, I've seen them rub the rotor before.
This doesn't sound like a spring or strut, I'd check rotating components first.
Old 06-25-2004, 09:55 AM   #13
Ramsey
Member#: 8813
just in case, you might want to retorque that wheel. your description matches exactly the condition of loose lug nuts.
Ramsey is offline   Reply With Quote
Old 06-25-2004, 10:15 AM   #14
csleee
Member#: 17861
thanks ill check things out today
actually i am missing a lug nut. when i was installing my suspension i had my friend torque down the lug nuts and asked him several times if they were tight, but apparently not.
Old 06-25-2004, 05:44 PM   #15
csleee
Member#: 17861
well i put my new lug nuts on and that seemed to solve the problem
as i was taking the old ones off they were really loose so i guess the noise was loose lug nuts.
Stoptech, progress, Cusco, Ground Control, Koni Etc... NinosAutoAccesories Suspension/Brakes/Handling 6 09-14-2004 04:49 PM
help with ground controls/koni csleee Texas Impreza Club Forum -- TXIC 1 05-21-2004 03:01 PM
Ground Control/Koni need help deuce.five Brakes, Steering & Suspension 1 04-12-2004 04:50 PM
Ground Control / Koni vs. coil-overs AnimalMother Brakes, Steering & Suspension 32 05-12-2003 02:31 PM
Stock struts with Ground Control Coilover's (making weird noises in rear) ResQDawg3 Brakes, Steering & Suspension 6 02-06-2003 09:37 PM
