Old 06-24-2004, 03:39 PM   #1
Daveish
Member#: 8935
2001 Impreza 2.5RS
Default Q on tial wastegate
Quick question on a Tial wastegate (the smaller one they sell, I think it's 40mm?)
Does anyone know the specs on the hole on the top of the wastegate? I don't have a fitting in there right now to hook up a vacuum hose to, and I'd like to drop by autozone or whereever and pick one up, without having to remove the wastegate from my car.
I think it's a banjo bolt... but can I go somewhere and say " I need a _______ banjo bolt " and get the right one?
Thanks in advance!
Daveish is offline   Reply With Quote
Old 06-24-2004, 05:50 PM   #2
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
I don't know the hole, but the smaller tial wastegate should be 38 mm, if it's an older model, 35mm.
cRayZee is offline   Reply With Quote
Old 06-25-2004, 12:16 AM   #3
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
He's talking about the bolt hole on the top. It is a banjo bolt- but I don't know the size. Mine came with the bolt.
Drac9 is offline   Reply With Quote
Old 06-25-2004, 07:56 PM   #4
Daveish
Member#: 8935
2001 Impreza 2.5RS
35mm sounds right. It was the same wastegate off a ludespeed kit, back in the day. Mine had the bolt too, but a shop took it off when they made me new gaskets for the wastegate and I didn't notice til' much later.
Old 06-26-2004, 04:34 PM   #5
sidewayz
Member#: 5810
2001 S366 2.5RS
you dont need anything on the top of it unless you are running a boost controller....
sidewayz is offline   Reply With Quote
Old 06-28-2004, 01:08 AM   #6
Daveish
Member#: 8935
2001 Impreza 2.5RS
Yah, I am running an EBC now... which is why I need to find the bolt for the top.
Old 06-10-2005, 09:20 PM   #7
XS_WRX
Member#: 61519
2004 Subaru WRX
cammed,built,35R'd WRSTi
Without the top banjo bolt connected you wont be able to control your pressure.. you'd only be able to get the spring rate boost.. nothing higher.
Example: if you have a 1bar spring you'd only be able to boost 14.7 psi
-alan
XS_WRX is offline   Reply With Quote
Old 06-11-2005, 12:17 PM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
It should be a Tial 38mm wastegate.
I think that unless you're runnin an electronic boost controller, you don't need anything on that top hole (just needs to be open to atmosphere).
You might want to try giving Road Race Engineering a shout about that, though. They should be able to sell you the right one.
Old 06-11-2005, 01:35 PM   #9
dunk
Member#: 15359
Ron at forced performance has them.
Duncan
dunk is offline   Reply With Quote
Old 06-11-2005, 08:13 PM   #10
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
I think it's a 6mm banjo. I'll double check tonight w/ some calipers. I have my top one out right now anyway because I'm breaking in my new S2 on the spring.
-Jared.
PunKidd is offline   Reply With Quote
Old 06-12-2005, 07:26 PM   #11
sidewayz
Member#: 5810
2001 S366 2.5RS
holy crap...way to bring back a year old post
Old 06-12-2005, 08:38 PM   #12
XS_WRX
Member#: 61519
2004 Subaru WRX
haha.. oh well
Old 06-13-2005, 09:54 AM   #13
PunKidd
Member#: 8533
2002 2.5 RS-T
Wow, didn't notice that was started in 04
Garrett 60-1 turbo / NEW Tial Wastegate / NEW Tial BOV Dr. Dooms Engine/Power/Exhaust 6 04-21-2015 11:56 AM
Tial Wastegates on backorder? 07EJ255 General Community 0 03-17-2008 06:46 AM
UR Ultimate-Racing External Wastegate UP PIPE + TiAL Wastegate XS_WRX Private 'For Sale' Classifieds 15 02-27-2006 12:13 AM
Installed a Tial wastegate Joe Hogan Normally Aspirated with bolt-on Forced Induction Powertrain 13 07-31-2001 09:24 PM
TiAL Wastegate for Minnam? sanders Normally Aspirated Powertrain 1 03-01-2001 10:13 PM
