Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 06-24-2004, 03:53 PM   #1
RavSpec
NASIOC Storefront Vendor
Vendor Sales Rating: (88)
Member#: 26854
2002 Impreza
WRX
Default Summer Big Sales !!!!!
ARC Super Air Induction Intake System for GDA(B) - $359.
Ready to ship !!!
ARC intake VS regular intake.
ARC has developed it’s own unique version of Induction and Intake Chmaber. The Intake Chamber helps raise the torque at low and mid range engine speeds and is also effective in improving accelerating speed.
The Induction box reduces intake resistance and increasing the amount of air taken in makes higher pressure possible. In addition, by trapping the air, it retains the appropriate amount of air inside and is effective in improving accelerating response.
When these 2 items are used together, it will improve torque and accelerating response throughout the RPM ranges
Perrin Fuel Rail Kit for 02+ Impreza - $439 (NO STI)
Perrin Fuel Rail Kit Includes :
BILLET ALUMINUM RAILS
FUEL PRESSURE REGULATOR MOUNT
STAINLESS LINES AND FITTINGS
The stock fuel rails and lines allow more fuel and pressure to be distributed to other cylinders while cyl #3 runs lean. When WRX owners begin upgrading the engine with high performance components, this problem gets even worse.
The PERRIN Performance™ Subaru fuel rail kit solves all fuel distribution problems. Fuel rails direct fuel to both banks of cylinders and to the fuel pressure regulator. Even fuel distribution is achieved through the PERRIN™ design guaranteed!
Perrin Intake System " BIG MAG" for 02+ Impreza WRX and STI -$219
PERRIN Performance™ produces an intake system, which is designed to prevent MAF output value from being pegged on heavily modified WRX engines and all 2004 STi with boost increases from stock. When using the factory MAF sensor and adding large amounts of boost the stock MAF sensor will max out and not allow additional compensation for air flow.
• The PERRIN™ "Big MAF" intake system will allow additional airflow to go around the sensor keeping the output value within factory specs.
• High temperature silicone is available in any of our three colors. (Red, Blue, or Black)
• "Big MAF adapter is high polished aluminum.
Fitments include: 2002+ IMPREZA WRX/STI, BAJA TURBO AND FORESTER XT
Perrin Turbo Inlet Hose for 02+ Impreza WRX and STI -$239
Add style under your hood and increase horsepower with the Perrin inlet hose kit. This silicone hose removes the original restrictive plastic hose found on the WRX. The hose is Constructed of durable 5-ply silicone (competitors us a cheaper 3-ply system). Non-corrugated, smooth internal bends combined with a mirror smooth interior finish to raise intake velocity and horsepower. Won’t crack or split like factory hose. Does not require removal of intake manifold! Fittings are included with the kit.
Perrin Intercooler Hose Kit for 02+ Impreza -$139 (NO STI)
PERRIN™ designed air passages ensure equal boost to all areas of any top mount intercooler. No sharp turns!! PERRIN™ intercooler hoses will remove the original problematic plastic hoses found stock on the 2002 and newer WRX. The non-corrugated, smooth glossy finish will raise boost velocity and horsepower
INTERCOOLER HOSE KITS INCLUDE:
Y-PIPE
THROTTLE BODY HOSE
BLOW OFF VALVE CROSSOVER
NEW SPECIAL HOSE CLAMPS
ILLUSTRATED INSTRUCTIONS
Greddy EVO II cat back exhaust system for 02 to 04 WRX / STI. Now in full stainless steel !!!
$ 569
Get them while they last. Not too many left.
Click link here to purchase or more detail
STI OEM Muffler. 2.25" piping with 4" Tip - $399
GT Spec Intercooler Splitter for GC8 - $99
Let us know if there's something you looking for that it's not posted here and feel free to contact us for questions and purchasing.
Ravspec
[email protected]
718-358-6102
RavSpec is offline
Closed Thread
APR and Carbign Craft Summer '08 Sale! Lots in stock and on sale. GNV Motorsports Exterior/Styling 34 06-27-2008 12:29 PM
BIG SALE. 04 WRX OEM intake scoop(front tube),catback. BIG SALE jasonpig Engine/Power/Exhaust 21 04-01-2007 08:45 PM
Summer Big Sales !!! RavSpec Suspension/Brakes/Handling 2 07-12-2004 04:29 PM
Summer Big Sales !!! RavSpec Exterior/Styling 12 07-08-2004 03:02 PM
