Old 01-16-2001, 07:59 PM   #1
Digital_Boy
Member#: 730
Question Oil and fuel starvation in tight turns? Are there baffled oil pans and fuel tanks?
Hey all,
I tried searching, but couldn't find anything conclusive, but I thought I remembered seeing a thread about oil aeration on some Impreza's running really sticky rubber on road courses.
Is this an issue with the Impreza? If so, does someone make a baffled oil pan to help counteract this effect?
Same with the fuel tank. I recall Jay_UK's description of his solution, a surge tank just downstream of the fuel tank to outlast the fuel deprivation that hard cornering produces.
I ask because I will need to replace the oil pan on my hybrid L, and if oil starvation is an issue, I'd like to address it right now before I get into a situation at a track event.
Thanx
Digital_Boy is offline   Reply With Quote
Old 01-17-2001, 03:55 AM   #2
Jay_UK
Member#: 296
Post
There are a few options available.
I have seen a larger capacity cast oil pan (with baffling). This costs about 600 dollars..
What I do for people is to strip the stock sump (removing the existing plates) and fit extra baffle plates inside.
As for fuel..you already know the solution.. A surge tank.. I am shipping one over for someone to test for me.. to see if it will fit..etc...
J.
Jay_UK is offline   Reply With Quote
Old 01-17-2001, 01:25 PM   #3
rjones
Member#: 1477
2003 wrx wagon
Post
Also for the oil starvation problem, there's a surge tank sold under the name Accusump, which essentially squeeze more oil into the system when oil pressure drops and takes it back when it rises. This may be a cheaper solution than a highly baffled pan.
cheers
rj
rjones is offline   Reply With Quote
Old 01-17-2001, 03:15 PM   #4
gimpster
Member#: 2295
Post
rjones: doesn't Moroso make something similar?
gimpster is offline   Reply With Quote
Old 01-17-2001, 03:58 PM   #5
Sean McElderry
Member#: 526
1995 Supra Turbo
Red
Post
Get the surge tank for your fuel problems. There's nothing I hated more than taking a hard right, uphill corner and having no fuel halfway through the corner. Then you gotta deal with that whole "spinning out of control" thing. What a pain.
Sean
Sean McElderry is offline   Reply With Quote
Old 01-17-2001, 04:30 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
Jay_UK, I pm'd you.
Old 01-17-2001, 08:01 PM   #7
Digital_Boy
Member#: 730
Post
Does the Accusump also act as an engine pre and post oiler? I've heard of systems that save a half quart of oil and can pressurize the oil passages before the engine cranks over, and can also trickle feed cool oil to a hot turbo after shutdown.
Any links to the Accusump?
Jay, if you could PM me with part numbers or descriptions of the surge tank, I'd appreciate it.
Are there different types of coolant reservoir tanks?? STiGuy23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-17-2010 12:04 AM
rotated rotors... now vibration/clunk in tight turns 03boxer4 Brakes, Steering & Suspension 0 03-29-2009 10:19 PM
Popping noise from trans in tight turn DONAUDI Transmission (AT/MT) & Driveline 5 02-19-2005 09:09 PM
The RA comes w/ a collector tank to prevent fuel starvation in hard cornering BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 11-28-2003 03:04 PM
ne1 solve the fuel stravation in right turns problem? Bassem Normally Aspirated Powertrain 14 12-06-2000 08:03 AM
